hot cam
Old May 23, 2007 | 11:32 PM
JACK FRISSINA's Avatar
JACK FRISSINA
Default hot cam
what can i expect with a cam as my first mod on a 06 a6 , do i need headers with this mod ?:o
Old May 24, 2007 | 12:12 AM
glennhl's Avatar
glennhl
Yes, you need to do headers with a cam to allow the engine to breath. Now with the converter available, you have a very large choice of cams. Before the converter was available you had to use a pretty small cam.
Old May 24, 2007 | 12:23 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
What converter are You refereing to?
Old May 24, 2007 | 12:44 AM
Maui's Avatar
Maui
St. Jude Donor '08
torque
Old May 24, 2007 | 01:49 AM
glennhl's Avatar
glennhl
http://forums.corvetteforum.com/show....php?t=1710472
Old May 24, 2007 | 08:57 AM
JACK FRISSINA
Default hot cam
question was , what can i expect for my first mod , a cam . i meant as far as dyno results and et , cam headers , and halltec ,will be my first attack , trying to reach 400 rwhp, im sure someone has done this , of course a tune is a must have .any input will help , thanks .
Old May 24, 2007 | 09:48 AM
mannyolivarez03's Avatar
mannyolivarez03
St. Jude Donor '08
Jack,
Below is a list of heads and cam that I put on my C6 last week......my car is a M6
Just had the following installed on my 2005 C6 with M6 tranny...
All work done by LG Motorsports..........Hope this helps Manny
AFR 205s, 921 upgrade, (64cc chamber)
FAST intake, ported to match the AFRs
ARP Head bolts
G5x3 cam, 114 comp 7.4 push rods
Ford Racing 30lb Injectors
NEW cometic multilayer steel head gaskets
Halltech Stinger Intake
Comp R upgraded hydraulic roller lifters
Car dynoed at 465.4 Max Rwhp with 428.1 ft/lbs tq
Old May 24, 2007 | 11:09 AM
cbrf4i1's Avatar
cbrf4i1
Originally Posted by mannyolivarez03
Jack,
ARP Head bolts
30lb injectors? that is smaller what came stock on the ls2. is this right?
Old May 24, 2007 | 11:12 AM
mannyolivarez03
St. Jude Donor '08
Dont stock come with 26lb injectors.......I could be wrong....
Manny
Old May 24, 2007 | 11:16 AM
cbrf4i1's Avatar
cbrf4i1
Manny
no, i believe it is 33.1lb if memory serves me correctly. 26lb was on some c5.
Old May 24, 2007 | 03:01 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
A cam alone will do you 35-50 RHWP depending on the cam.
A cam with out headers and heads is foolish. A CAI, CatBach, Heads, Headers & a cam is the way to go. If you're going to do a cam it makes sense to replace the heads as well - no extra labor. Do the above and you'll get 90-120 RHWP.
Remember the weakest link in our cars are the valve springs. Float @ 6,300-6,500 RPM. That's an extra $700.
Old May 24, 2007 | 07:34 PM
JACK FRISSINA
Default hot cam
great info , thanks.
Old May 24, 2007 | 07:48 PM
TLewis4095's Avatar
TLewis4095
Give us a call to discuss your options & what to expect, we are right in your back yard & we can show you the results of other C6's like yours with their mods. www.RevXtreme.com 813-628-0080
Old May 24, 2007 | 08:28 PM
chucky7's Avatar
chucky7
Give us a few examples of some of your other C6 mods and results
Chucky7
Old May 29, 2007 | 04:25 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
You can do a cam without heads and be fine. We've done it hundreds of times and made great power. There's a LOT of extra labor and cost when you add heads to the equation. You're looking at having to remove the intake manifold, all of the fuel lines, exhaust, etc. There's a lot more work that has to be done to put heads on. So if somebody is going to charge you the same labor for a cam only or a heads and cam package, you better get that in writing.
As far as $700 for the springs, somebody definitely saw you coming... you can get the Comp Cams 26921 spring kit, that comes with springs, seals, seats, and titanium retainers all for less than $600.
Old May 29, 2007 | 04:31 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
So you're goint to bust my chops for a $100
That set lists for $789 on the compcam site
Old May 29, 2007 | 04:46 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
Chucky7
Just a few quick examples, off the top of my head. (All hp/tq numbers are REAR WHEEL numbers.)
06 C6 A6 - Cam/heads/full exhaust/Honker/n2o Car made 435 n/a and 510 on a 100 shot.
05 C6 A4 - Procharger P1SC/3200 stall/3.42 gears/full exhaust. Car made 525.
05 C6 A4 - Cam/heads/full exhaust/Fast intake. Car made 445. We were also featured in Vette Magazine for that car.
07 Z06 - Honker/plugs/wires/tune. Car made 462.
05 C5 M6 - Cam/full exhaust/Vararam. Car made 405.
To hot cam
Old May 29, 2007 | 04:51 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
Must be nice to be a baller... $100 is a nice chunk of money, at least to me.
I sell that set for $599.95.
Old May 30, 2007 | 08:57 AM
AintQik's Avatar
AintQik
Ford injectors are rated using the Ford rails/system. On our system the 30#s are more like 40 pounders.
Old May 30, 2007 | 09:45 AM
valdeztke's Avatar
valdeztke
ZZZZZZzzzzzzz wake up!
