DOT 4 Brake Fluid advice
I've been planning on putting some DOT 4 fluid in the car as I autocross the car and want to get some better fluid that handles some higher temps and I hear it also doesn't break down as quick as regular fluid.
I bought SSBC's DOT4 ( purple stuff ), and I never noticed before, but the label says "Do not use with ABS systems"
What do all you track rats use in your Cars??? Since most C4's and all the late model cars are ABS equipped and I know there's a ton of you that do this...
Any advice, help or suggestions would be greatly appreciated.
Thanks!
Fluid temperatures aren't likely to be an issue in autocrossing, you just aren't on the brakes long enough during a minute's run to get the fluid that hot. I go on the theory that a good flush and new fluid is more important than the best possible dry boiling point.
Thanks!
Sounds good. My SS already has DOT3 from the factory just as the C6 does.
Maybe I'll just do a good flush. The SS sucks in that the clutch and the brakes draw from the same Master cylinder.
Thanks guys
All you ever wanted to know about brake fluid, courtesy of StopTech:
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
This car is annoying me with the clutch fluid being shared... gotta find a place that can do it. If it was just the brakes, I'd do it myself.
