Another A.C. problem HELP!
Old May 25, 2007 | 08:25 PM
old stingray's Avatar
old stingray
Default Another A.C. problem HELP!
When I push the A.C.switch the light comes on for 2-3 seconds then goes off,it doesn't flash.The compressor clutch doesn't kick in.The fuses,relay are good and outside temp. sensor is reading correct. Any ideas? Thanks
Last edited by old stingray; May 25, 2007 at 08:29 PM. Reason: This is a C5 posted in C6 section
Old May 25, 2007 | 08:55 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
I have the same problem, I push it then the switch flash again.
Old May 26, 2007 | 07:13 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
have you checked the pressure in the system, your a/c may need to be recharged.
Old May 26, 2007 | 10:26 AM
old stingray
No,I haven't had a chance yet.I see you're right next door.
Old May 27, 2007 | 09:05 PM
old stingray
ttt
Old May 27, 2007 | 09:31 PM
Skunkworks's Avatar
Skunkworks
Although may not be related but… on my 07 if I killed the AC with snow flake button and pressed it again to enable AC it does not always turn ON unless I hit AUTO button then it’s good or working.
Mike
Old May 28, 2007 | 10:52 AM
old stingray
Mike
Thanks,tried it,but no luck.
Old May 28, 2007 | 10:55 AM
Whiterock1's Avatar
Whiterock1
There's a high pressure cutoff switch on a/c systems which sometimes goes tango uniform. May not be the case, but if it failed in the off position, it wouldn't let the compressor run. Easy test--for someone who knows what they're doing, and fix I've heard. Good luck!
Old May 28, 2007 | 10:57 PM
old stingray
Thanks for the info.
Old May 29, 2007 | 06:45 AM
Zig's Avatar
Zig
well sorta. yes, va. is right next door. we almost bought a house in moutain city, my folks live in elizabethton, my avatar is me on the bristol speedway (the worlds fastest quarter mile ) during the tennessee state hog rally, and stafford/fredericksburg va isn't really that far.
i'm suspecting it should be a quick fix for the a/c issue but then again....
shouldn't cost much more than $50 to get it checked, imo, your dealer should be able to do a quick pressure check for you as a 'courtesy'.
To Another A.C. problem HELP!
