St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Engine Drag Control Active????
Lately my DIC has been flashing the "Engine Drag Control Active " notice. It started right after I put Z06 rear fenders and bigger rear tires on. Has anyone had this happen?
I upped my tires to 275 front and 305 back. When I have these tires on, traction control engages whenever I give it full throttle and reduces my HP. I also don't have Tire pressure sensors on these tires. Not sure if it is tire size or the lack of tire pressure sensors causing this problem. I just end up turning it off and all my power comes back.
If your car is doing it on other than a downshift you have either ECM problems or badly mismatched tire sizes front to rear and have the ECM confused.
If any of the experts knows how "drag control" is done please chime in. I'm curious as to what is controlled and how. If some one downshifts from 5th to first at 75MPH what can the ECM do to keep from mechanically over revving the motor?
Edit; I just went thru my service manual, see my post @ 7:31PM.
Reason: Remove first sentence
Think of it as traction control backwards. It's designed to help keep the rear wheels from locking up on a downshift (mechanical over rev). If your car is doing it on other than a downshift you have either ECM problems or badly mismatched tire sizes front to rear and have the ECM confused.
That's the first time I ever heard of that one! Is is in the manual, or did Chevy add it as a surprise???
My car is a manual Z51. I've added a supercharger, heads, cam, headers and exhaust. The tire sizes are 245/40/18 in the front and 345/30/19 in the rear.
The DIC notice comes on when the engine is revving down. I'm not always downshifting when the notice appears.
When the driver releases the throttle, and the drag from the engine overcomes the frictional force between the tire and the road, the EDC becomes active.
The EBCM sends a torque request signal to the PCM, which stabalizes the torque at the wheels by reducing the slip at the driven wheels.
When EDC is active, the driven wheels are controlled to a target below the non-driven wheels.
Pg 5-205 under antilock brake system.
Nothing to protect from a downshift over rev. Either the tires break loose or you get a massive over rev from the rear wheels driving the engine.
Thanks for the comments,
Jeff
AT barely over 1% difference in rear tire diameter you shouldn't have any problems.
That's closer to 6% with those sizes. Way too much. The pcm thinks the rear wheels are slipping when you let off the throttle because they are going so much slower than normal.
Jeff
Jeff I'm pretty sure your rear tires are too tall and the front rear ratio is off causing this. As it happens, Doug whose car is at Rogers now bought some replacement tires and got fronts that are too tall. Shoot him a PM, maybe you guys can work out a deal! There is a tire size converter at Tirerack.com IIRC - you can see how far off your ratio is vs stock.
Houston, I think we have a problem! OK, appears that my front and rear tires don't match up and as a result the PCM is getting a false positive reading. I can live with that.
Question: will this cause any harm/damage to the engine? Here's my reason for asking. Just put brand new Michelin PS tires on less than 500 miles ago and you can guess the rest.
Any responses to my question will be greatly appreciated.
345/30/19 @ 85.26" circumference, a 1.07% difference.
And with stock size fronts 1% difference in the rear diameter should not be enough to cause a problem.
His fronts are stock, 245/45/18. NOT 285/19's.
Jeff, I'd get it fixed. My car freaks out when I drive on my short 26" drag radials and does spooky things with active handling... If I forget to turn it off. It usually happens during lane change manuvers, I can feel the car applying the brakes and fighting me changing lanes.
I would not want to see what would happen if I had a real emergency with the mismatched tires that required the active handling.
Seriously, PM GTOdoug a fellow HP Sales customer. He has some tall front tires he's replacing for precisely this reason.
Jeff, my car is over there now. They will be switching out wheels and tires shortly. The Tires that are over there are Bridgestone RE50A's. They are 255/40/18's which are 26" tall. I don't know if this will fix your problem, but I paid 450 new. They are used since Jan 15th. They have approx 2000 miles on them and look new. $200 bucks takes them. Tell them to referece this thread as I'm leaving town for 10 days and won't be able to communicate anything to them.
The difference between STOCK REAR size and his reported REAR size is 1.07%. He claimed STOCK FRONT size so there won't be a difference.
The Active Handling, Traction Control (and Engine Drag Control?) depends on STOCK front to rear stagger. You can run any wheel/tire size Front to Rear that fits in the wheel wells if you maintain the stock stagger.
The STOCK Front to Rear stagger is 4.25%.
