Lowering.........Help !!!!!
Old May 31, 2007 | 07:44 PM
cargeek's Avatar
cargeek
Default Lowering.........Help !!!!!
Hi....I bought lowering Bolt Kit and used them on rear.. that worked to make back where I like it, however it appears it raised front a whisker...my question is: its there enough ajustment in factory front set up to drop the front a whisker?
Thanks, Doug
Old May 31, 2007 | 09:48 PM
BEZ06's Avatar
BEZ06
Thanks, Doug
Yep - I don't think there is anybody that hasn't gotten the front as low as they want it with the factory bolts.
Bob
Old May 31, 2007 | 11:12 PM
drivinfast's Avatar
drivinfast
Default yes
on mine, I lowered the front all the way on stock bolts, if I lower the rear all the way on the aftermarket bolts the car sits even, no rake.
so I keep it around 2 or 3 turns from the end.
my 2@
Old May 31, 2007 | 11:50 PM
cargeek's Avatar
cargeek
Default Ok...I will try stock front bolts
HI..I will try to lower front 1/2 to 3/4 with stock front bolts..it should work..I will let you know..thanks for all the advice..
Doug
Old Jun 1, 2007 | 01:54 AM
ZO6 Fan's Avatar
ZO6 Fan
Thanks, Doug
Look into the "Zip Corvettes" lowering kit- dropped mine 1 1/2" -2" evenly all the way around and the kit is designed to protect the aluminum A Arms.
To Lowering.........Help !!!!!
