P0358 need Phelp
Old Jun 1, 2007 | 01:49 PM
Z06Norway's Avatar
Z06Norway
Default P0358 need Phelp
Need help, car is running on 7 cylinder, and P0358 DTC showing up.
I checked wiring harness, borrowed a new coil, start here up and header 8 is cold to tuch with my hand.
Changed spark plug and voila, she fired up on all 8, after a 15 minutes short trip engine started to hesitate and run on 7 again
http://www.gearchatter.com/viewpost14756.php
I dont have a Tech II, so i cant check all on this page
But i suspect the PCM to fail ????
Or does anyone else have a better solution ?
There is 4 wires to the coil
12 volt
Ground
1 volt reference
IC ground that trigger the coil ?
regards
Rune
Old Jun 1, 2007 | 02:01 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
any possibility that the plug wire is loose and or not 'snapping' onto the plug completely?
Old Jun 1, 2007 | 03:38 PM
Z06Norway's Avatar
Z06Norway
Nope, i even borrowed one from my friend,
Rune
Old Jun 2, 2007 | 12:52 PM
Z06Norway's Avatar
Z06Norway
Default solved
or atleast i think so.
I borrowed my friends wire, changed spark plug and coil, voila
she works again :-)
god how much better a V8 is than a V7 :-)
But i am still worried
Rune
Old Jun 3, 2007 | 10:20 PM
cerino2000's Avatar
cerino2000
That code comes back to:
Ignition Coil H Primary/Secondary Circuit Malfunction
My vote is that it is in fact the coil just went bad.
To P0358 need Phelp
