CAGS connector is different!
Old Jun 6, 2007 | 04:35 PM
Thrill6's Avatar
Thrill6
Default CAGS connector is different!
I just received my CAGS eliminator and the connectors are different and it doesn't fit!!!! I have an '07 vert/Z51. I've checked all the standard online Corvette supply places and none of them show a different part # for 07 or Z51. The new connector is still oval, but the male part of the connector is "T" shaped. Anyone else have this problem?
Old Jun 6, 2007 | 07:29 PM
VET4LES's Avatar
VET4LES
Are you sure you are looking at the right connection? Their are several on the manual transmission. It is clearly marked CAG.
Old Jun 6, 2007 | 07:56 PM
scrannel's Avatar
scrannel
Yeah, for a while I was trying to plug into the wrong wire until my blind, deaf & dumb cat crawled under the car and pointed out the correct one.
Old Jun 6, 2007 | 08:27 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
All you have to do is remove the #10 fuse which is connected to nothig else and that will take care of your CAGS.
Old Jun 6, 2007 | 10:19 PM
cbrf4i1's Avatar
cbrf4i1
and the check engine will be on soon after.
Old Jun 6, 2007 | 10:40 PM
VET4LES's Avatar
VET4LES
It's been tried and the comes on often.
Old Jun 6, 2007 | 10:51 PM
cbrf4i1's Avatar
cbrf4i1
just use th 2.2k resistor from radio shack, i have been using it in all my cars since 97, not one failure. some of these cags are not the most reliable.
Old Jun 7, 2007 | 05:52 AM
timd38's Avatar
timd38
Get a Preditor and turn it off.
Old Jun 9, 2007 | 10:25 PM
Thrill6's Avatar
Thrill6
Ok, this was user error!!! After jacking up the car, I looked under it and saw a connection near the bottom of the transmission in the back and assumed this was the CAGS. Today I jacked up the car and crawled underneath and the CAGS connection is above this connection near the top of the transmission.
To CAGS connector is different!
