Camshaft Sensor
Old Jun 11, 2007 | 02:04 AM
Myth's Avatar
Myth
8th Gear
Default Camshaft Sensor
I have a problem with my 06 C6 A6. The check engine sign turned on yesterday, the diagnoses was : Sensor camshaft !! So i bought a new one and installed it, the sign cleared for about an hour or so, then it turned on again and when I checked it said Sensor camshaft AGAIN!!! Does anyone knows what is going on?!!
Old Jun 11, 2007 | 03:55 AM
shopdog's Avatar
shopdog
Did you perform the crank variation learn procedure? You have to do that any time you change the sensor.
Old Jun 11, 2007 | 07:54 AM
Myth's Avatar
Myth
8th Gear
Actually, i do not think i know what is that procedure! Could you please explain how to do that?
Old Jun 12, 2007 | 01:31 PM
shopdog's Avatar
shopdog
Its in the service manual. You need the Tech II service tool to put the ECM in learn mode. Then just follow the instructions on the Tech II screen.
To Camshaft Sensor
