Brake help needed "makes pufffffffff" sound
When I got in and depressed the brake pedal it went to the floor and made a "puffffffff" sound. You can pump the pedal and it still makes the sound and the pedal goes almost to the floor. After several pumps it builds up. Also, I get a clicking noise each time. They say it is the brake interlock - true - but I've never heard it before.
Well, the service manager came out and we went for a test drive. He could not re-create the issue. So, on my way home I played with the brakes. Pedal goes farther than before and I get a vibration when depressing.
Any thoughts???? Searched with no luck on the forum.
I need to report my findings and always find it helpful if I can point them in the right direction. When the brakes are applied, I do stop just seems like a lot of travel and pedal virbation.
The "pufffffffff" noise comes from the big black round thing in the engine compartment in front of the drivers seat near the brake fluid.
Thanks in advance.
Accidently posted in the General Section.
Until you get it fixed just tell people that you have AIR BRAKES
Not real sure what the end result was but I have brakes. I think that maybe something got bumped when the power steering hose was fixed and they found it - along with a complete system check.
Anyway, thanks for the pointers. It really helped.
