Does anybody have a list of what injectors will fit the C6 wiring harness. I'm aware there are harness conversions available but I wanted to see if I can find a set of injectors that would just plug and play. I see them forsale in many forums, I just don't know what works.
Maybe a better question would be for someone to tell me what are my options for 42# injectors for the C6. I run a FAST and I'm aware I need to run different o rings. By the way, 4.6 Mustang o rings work just fine in the FAST and are cheaper.
For example, I'm looking for a list of 42# (or close) injectors and what is needed:
Ford Racing Red Tops - Require harness splice
Racetronix p/n xxx 42# plug and play
Accel p/n xxx - Require harness
etc...
Was hoping somebody did this research already for me
I am pretty sure the injectors that come with the L76 intake/tb/fuel rail should fit without any adapting. Could be wrong though, it's happened before.
Yes, they do, Spin has them on his car. I think they are 40s which would work but I also think they are still pretty expensive. What are the LS7 injectors? 38? Mine are completely done on the 404.
If anything would be plug and play, you'd think it would be the LS7 injectors. I was told they were 40#. It seems odd that info is so hard to come by on this. Are you shooting for 80% duty cycle or what?
etc...
We have M145FM Siemens DEKA 5 injectors which flow apx. 54lb/hr @ 58PSI (46lb/hr @ 43.5PSI). They are the correct length for the LS2 intake/rails and have the correct USCAR connector. You can order these through Jason @ LPE or Angie @ Thunder Racing.
