How hard is it to install kooks headers with hf cats and x pipe in my garage on stands and ramps.Is there enough room to put the headers in from the bottom of the car.THANKS GARY SORRY FOR THE REPOST
I just installed 1-7/8" Kooks, both went in from below, fairly easy with some patience.
Passenger side was smooth without having to remove anything, drivers side required me to remove the back 3 spark plugs. These went in more better than Dynatechs on my C5 did.
I should mention I have a 4 post lift, so I have lots of room to twist and play with the headers, this might not be the case if you're using jackstands.
