suspension experts... question....
Old Jun 23, 2007 | 02:18 PM
REVAK's Avatar
REVAK
Default suspension experts... question....
Put Koni FSD's on my 06 Z51, and as others have noticed, the car does sit lower , maybe 3/8 ". Didnt mind the drop till I noticed that the air dam now scrapes just about everywhere. Per shop manual was able to adj. to get back to original height, however to do so, I had to take the adj. bolts farther than the recommended range. [ manual says minimum of .745" of the adj bolt should be exposed above the mount. } So either I run the car lower and schread the air dam or over extend the adj. bolts. Can the adj. bolts tolerate the additional extention ? Any advice would be appreciated, thanks in advance.....Revak
