problem lowering z51
Old Jun 25, 2007 | 09:00 PM
jetning's Avatar
jetning
Default problem lowering z51
can't get to drop the lower arm to remove the lowering bolt. what do i do? thanks.
Old Jun 25, 2007 | 09:11 PM
Nightstalker Medic's Avatar
Nightstalker Medic
I removed the hardware for the sway arms lower nut and the top bolt. This was done for both front and rear sways. Sways fell out of the way, then removed the bolt for the rear and bolts for the front shocks and then I was able to jack up on the spring.
Old Jun 25, 2007 | 09:22 PM
sallen619's Avatar
sallen619
Why remove it????
Old Jun 25, 2007 | 09:30 PM
jetning's Avatar
jetning
Originally Posted by sallen619
Why remove it????
i meant to remove the stock bolt and put the lowering bolt in.
Old Jun 25, 2007 | 11:01 PM
cargeek's Avatar
cargeek
I bought lowering bolt kit from PFYC (39.95 I think) and they are fully adjustable..I dropped rear 1 1/4" and front 3/4" ...drove it for 100 miles and had 4 way alignment..car is perfect..
To problem lowering z51
