I have searched for threads and cant find any. Couldnt find anything in the manual either. Any ideas of the upper limit of side G force, when taking a corner? Assume good solid road, standard tires. I have had it up to .75 Gs, which is probably not a lot to some of you, but I cant find any information on limit. I am looking at my HUD, which provides that data. Thoughts?
I hit 1.02G on a A6 Z51 with no tire skid... But that was a right turn and not a skid pad circle. A true skid pad test would have to hold that G force longer than a quick turn I would think.
1.1 at 50mph on grooved concrete
1.05 at 60 on asphalt, with more to spare i believe
remember, conditions have to be ideal, my buddy took a roughly moderate turn on surprisingly wet pavement-surprising because either dew or a sprinkler made road slick, and he slid out-he was in a civic-his civic went to recycling and part of that metal is in his leg and the tree he hit is now firewood for his fireplace so it wasn't a total loss
with stock tires, GY run flats, about 1.00 G around a long corner with warm tires and a warm road. I push this car past it's grip limit all the time. Very predictable when it starts to slip. Back tires go out first if you push the throttle, but with gentle throttle, you can get up enough speed to where the fronts start to slip. I have a 2nd set of tires for the track, Toyo RA1's and they pull 1.15 G's consistently.
