Best Gears for A6
Old Jul 11, 2007 | 06:35 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Originally Posted by Gman57
Talked to Jenny today and I must say she is a great rep for your company. As a business owner myself I recognize someone that knows serving the customer comes first. Give her ...... you just made a customer out of me and when I do my gear swap you will be the people I do it with.
Thanks for the props and she does indeed do a very good job up there in the front office. She knows "cars" better than most and I guess it comes from being surrounded by them everyday.
Anytime you have a question, let us know.
Best Regards,
Phil
Old Jul 11, 2007 | 06:37 AM
DTE Powertrain
Collections Hold
Originally Posted by 1bdasvt
I am sooooooooooooo tempted to buy a DTE rear end!!!{Hey,..it's been a while since I did a performance mod!!}
I wonder how much $ install would be??
Installation w/ PCM calibration (if you have an auto) typically comes in around $400-$600, depending on your location and the prevailing shop labor rates in your area.
Phil
Old Jul 11, 2007 | 09:25 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Phil
Thanks Phil.
I'll give You guys a call soon,but wanted to ask You,on mY A6,what type of "performance" would I gain{or notice} over the "stock" rear end?
Old Jul 11, 2007 | 12:03 PM
DTE Powertrain
Collections Hold
Thanks Phil.
A huge acceleration performance increase of the car with this 3.15 gear set, compared to the stock parts- which is pretty much the same gains everyone gets with their cars regardless of vehicle modifications when lower gear ratios are installed. The A6 equipped C6 Corvette reacts no different.
Phil
Old Jul 11, 2007 | 03:50 PM
Wingrider's Avatar
Wingrider
Hi Phil:
What are your thoughts regarding the above post and the need to re-turn after a break in period?
Old Jul 11, 2007 | 04:53 PM
DTE Powertrain
Collections Hold
Originally Posted by Wingrider
Hi Phil:
You'll need to have the TCM re-calibrated for the new shift points and transmission shifting strategies for this differential, (just like the C5 platform) in addition to the speedometer corrections also needed for the gear change, since the A6 driveline does *not* sample VSS from the differential like the C5 did, but rather from the trans. output shaft itself. Some of the A6 driveline engineering is totally backwards from what the C5 platform was.
Phil
Old Jul 13, 2007 | 01:57 AM
ScottJ03's Avatar
ScottJ03
Default The best upgrade...
We accelerate way more than we drive 140+. I love my gears! It makes more sense on the power band and not hard on the rest of the car. 3.15 is the way to go.
Old Jul 13, 2007 | 09:05 AM
Larry R. Quinn's Avatar
Larry R. Quinn
I agree 100% . After the install , you will ask yourself " why did I wait soooo long to get these gears ? " . You will not be disappointed !
Old Jul 13, 2007 | 02:29 PM
Vito.A's Avatar
Vito.A
The lower gears will also provide a much better deceleration from engine braking, as well as being easier on the brakes.
