Save My Battery From Heat
Old Jul 2, 2007 | 03:00 PM
mo-shy's Avatar
mo-shy
Default Save My Battery From Heat
What is the best way to save the Battery from the heat .
i opened my hood and found leak from the battery
one of the battery finger dont pass the electricity in normal way
i want protect my battery from the heat.
Old Jul 2, 2007 | 03:13 PM
knkali's Avatar
knkali
relocate to the trunk like the Z06
Old Jul 2, 2007 | 03:28 PM
timd38's Avatar
timd38
[QUOTE=mo-shy;1560910473]one of the battery finger dont pass the electricity in normal way
QUOTE]
We make 58 million batteries a year and I never heard of this before.
Old Jul 2, 2007 | 03:53 PM
VET4LES's Avatar
VET4LES
I don't understand the problem but take it to the dealer and have the problem corrected. Batteries will stand up to the heat but will not last as long.
Old Jul 2, 2007 | 05:44 PM
Abomination's Avatar
Abomination
buy an optima, 5 yellow tops later in vegas 120 degree heat and the soonest one pooped out on me was about 5 years. First mod on all my cars.
Old Jul 2, 2007 | 06:04 PM
mo-shy's Avatar
mo-shy
where i can find cover can protect my battery from the heat?
Old Jul 2, 2007 | 06:10 PM
VET4LES's Avatar
VET4LES
My guess is a cover will make it hotter. Good luck.
Old Jul 2, 2007 | 07:25 PM
timd38's Avatar
timd38
Based on were the battery is, you will keep the heat in it by putting a cover over it.
Old Jul 3, 2007 | 11:57 AM
calemasters's Avatar
calemasters
I do not know how a top post battery could leak. Is the case cracked?
Old Jul 3, 2007 | 12:21 PM
mo-shy's Avatar
mo-shy
I believe the reason the heat! cause after installed the headers i notice a lot of heat under hood + in the Cabin
Old Jul 3, 2007 | 12:29 PM
Abomination
Thats one reason I had the headers ceramic coated, reduce the heat as much as possible.
Old Jul 3, 2007 | 01:37 PM
timd38's Avatar
timd38
If you want a heat shield (battery wrap) for you battery, send me a PM with your address and I will send you one. That being said I think it is a mistake to put it on.
Old Jul 3, 2007 | 06:39 PM
mo-shy's Avatar
mo-shy
That will be nice from u
Old Jul 4, 2007 | 03:39 PM
Thrill6's Avatar
Thrill6
Battery blankets are meant to keep internally generated heat in, not keep external heat out. If your battery feels hot, its because heat is generated internally as your battery charges.
Fluid leaking out is usually an indication that the battery was overfilled when it was made, has been overcharged, or the battery is defective. If it has been overfilled, it could leak a bit for a few weeks until it gets the correct level. In the heat of the summer your battery will reach its largest charge and could leak some fluid, but this is normal. When your battery is hot, it can hold a bigger charge and it can discharge much quicker. Cold Cranking Amps (CCA) is used to measure battery performance because the colder a battery is the fewer amps it can discharge.
Check your voltage gauge, it should always be between about 12.0v and 14.6v. If it is above that level you have a problem with the charging system which can cause it to overcharge. If the voltage level is OK and the battery continues to leak, the battery is defective and you should replace it.
Old Jul 4, 2007 | 04:27 PM
timd38's Avatar
timd38
I agree with what you say except for the statement above. Many vehicles have heat shields to reduce battery temperature and we have a ton of data to support that they due, but as you stated, he has another problem. I have a few battery heat shields under my desk, so if he wants to prove to himself that we are correct, I am going to send him one.
To Save My Battery From Heat
