Check Engine Light ... Help
Old Jul 3, 2007 | 12:05 AM
kermooni's Avatar
kermooni
Default Check Engine Light ... Help
I have an 06 A6. In April I added the Kooks 1 7/8" headers with cats and X-pipe. LPE intake was added along with a tune. All was well until this afternoon when the dreaded "Check Engine Light" come on (in my RPM guage). No other error codes in the DIC. My car has 7777 miles on it.
Any ideas? Thanks.
Old Jul 3, 2007 | 12:27 AM
VET4LES's Avatar
VET4LES
You need to read the code with a code reader and post it. You will get some help then. Seems like the most common on is a C02 sensor.
Old Jul 3, 2007 | 12:43 AM
Muscles's Avatar
Muscles
Any ideas? Thanks.
Shoot, you are lucky. I freak out when my check engine light isn't on. Its been on 90% of my cars life!!! You got to love that A6!!!
G
Old Jul 3, 2007 | 12:44 AM
jjohn918's Avatar
jjohn918
That's my guess too. Unless your tune turned off the rear O2 sensors, you might be throwing those codes.
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Any ideas? Thanks.
Yeah, I have ideas.
Its probably due to the high flow cats. A common problem. If the tuner didn't turn off the rear 02s it is quite possible this is what you are looking at.
A few people have been able to run high flow cats and keep the rear 02s active without codes, but they are the exception and not the rule.
A code reader will tell you for sure
Old Jul 3, 2007 | 02:22 AM
TRJ's Avatar
TRJ
Any ideas? Thanks.
kermooni, PM sent...
Old Jul 3, 2007 | 03:28 AM
SpinMonster's Avatar
SpinMonster
I have Kooks, H/C, and every bolt on with no deleted codes and every friend I have that I tuned has no codes deleted with headers. No rear O2 codes need to be deleted with a proper tune. Anyone wanting to come to LI NY can get checked/scanned for free and I will get rid of the check engine light through tuning (also free for 2005's) unless there is a mechanical problem but I will let you know what that is so you can correct it.
Old Jul 3, 2007 | 11:04 AM
'06 Quicksilver Z06
I might take you up on that Spin.
Old Jul 3, 2007 | 11:12 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
G
Old Jul 7, 2007 | 11:54 AM
kermooni's Avatar
kermooni
Went back to my tuner - Olsen Corvette. It was the rear O2 sensors. He also found it strange that I would get an ECL after 3 months. But then we are having very hot and humid weather here. So he made adjustments - no codes were removed and all is well again
Thanks Max
Old Jul 8, 2007 | 10:54 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
To Check Engine Light ... Help
