Jet Hot Header Coating Info
Old Jul 11, 2007 | 10:10 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Default Jet Hot Header Coating Info
JET-HOT develops, produces and applies a variety of coatings. Properties of the various coatings include insulation, corrosion resistance, abrasion and impact resistance as well as lubricity. All are applied at one of their regional factories through a meticulous, multi-step process including: thermal degreasing, abrasive-blast stripping with virgin aluminum oxide, double-coating (inside and out on headers), high temperature curing, custom packaging for return shipping, and quality-assurance controls during every phase of the procedure.
Coatings fall into the following groups:
JET-HOT 1300 - This exclusive formula works beautifully on new or used parts at temperatures up to 1,300F. Sterling is our most popular finish, this high-luster coating, containing silver powder, shares the brilliance of chrome with the subtlety of nickel. It provides the most brilliant appearance in high-temp, high-tech coatings while delivering major performance advantages. Sterling is also an extremely easy coating to keep clean. The same basic formula is available in matte black, blue and cast-iron gray.
1300 Sterling $249.99
1300 Colors $269.99
JET-HOT 2000 - Formulated for very high temperatures, this rugged coating protects substrates up to 2,450F, heat levels sometimes encountered in Rodding and Off-Road applications. Available in black, blue or grey.
2000 Black/Grey/Blue $274.99
They recently added a new coating -
JET-HOT EXTREME STERLING™ - Similar to Sterling but will hold its shine up to 1,400°F and will protect parts up to 1,700°F. This coating insulates slightly better than sterling and is semi-textured. (Made from their MC-15 formula.)
Info and more pictures of the different colors can be seen at - TBYRNE Motorsports - Jet Hot Coating
We have all of the coatings on sale through July 31st. You can add Sterling and Extreme Sterling to regular priced long tube headers for $100.00. Add an additional $25. to that for colored coating and Jet Hot 2000 will be $150.00
Just note this when you place your order.
Have a great day!
Old Jul 11, 2007 | 10:19 PM
glennhl's Avatar
glennhl
Good info. Is there any way you can get the thermal conductivity of the coating?
Old Jul 12, 2007 | 09:11 AM
tbyrne's Avatar
tbyrne
Jet Hot provides the following info -
Because of its low emissivity and insulating effect, JET-HOT Sterling creates a thermal barrier to protect headers - inside and out - while reducing heat transfer into the engine compartment. But the good news goes beyond protecting headers from thermal fatigue. Plugs, wires, fan motors, water pumps and other heat-sensitive parts get a break, too, in a cooler environment. Plus, power normally increases and safety for racers improves with lower temperatures.
The graph shown to the left, developed independently by a major US automobile manufacturer, shows just how effectively JET-HOT Sterling beats heat. The company's engineering team was astounded by temperature reductions exceeding 300°F when JET-HOT Sterling was applied to standard exhaust components. Car Craft also took a cool breath, after measuring temperature reductions of over 60% on header surfaces following the application of JET-HOT.
Old Jul 12, 2007 | 09:21 AM
andyandy98's Avatar
andyandy98
Sounds like some very good prices for this.
Old Jul 12, 2007 | 12:43 PM
lemans 07's Avatar
lemans 07
I just ordered a set of Kooks thru your outfit yesterday. Is it possible to add the coating to my order? If so, what is the price with sale priced headers?
Old Jul 12, 2007 | 02:37 PM
tbyrne's Avatar
tbyrne
That shouldn't be a problem. Just give us a call or e-mail to change your order.
Thanks!
To Jet Hot Header Coating Info
