Steering Wheel Play
Old Jul 13, 2007 | 10:52 AM
Mad*Max's Avatar
Mad*Max
Default Steering Wheel Play
My steering wheel has at least a quarter-inch of play. For a car that is only 6 months old, I don't believe that it is normal. I wanted to know what kind of play others have, if any, in their cars.
Second, will I have any luck with the dealer or will I just get hypertension?
Old Jul 13, 2007 | 11:16 AM
RRVettes's Avatar
RRVettes
I had a similar problem with by 05 C6, where I had play in the steering. It was noticeable when the car was stopped, but most noticeable when in motion and changing lanes for instance. The dealer replaced the inner shaft in the steering column and the problem went away. This may be a place to start.
Old Jul 13, 2007 | 11:36 AM
AintQik's Avatar
AintQik
On the steering shaft there is a 10 mm bolt (at least on mine) that came loose and caused what you describe. Check it for tightness then follow advice in the second post.
Old Jul 13, 2007 | 12:10 PM
Mad*Max's Avatar
Mad*Max
Can you please describe where I will find this bolt and then I will check it.
To Steering Wheel Play
