Runs bad when it rains
Old Jul 22, 2007 | 11:37 AM
howellrcng's Avatar
howellrcng
Default Runs bad when it rains
The car is sitting in a parking lot when it rains and you go to drive away it immediately runs like crap til somethin' dries out. Has anyone had this happen? I know it is electrical but the engine compartment is dry when I lift the hood. I took the cover off of everything to try and find condensation with no luck......Sounds like a warranty issue to me but if it is a simple silicone fix please let me know.
Old Jul 22, 2007 | 06:54 PM
VET4LES's Avatar
VET4LES
Just a few things to check. Is the seal under the hood in the front OK? Have you changed the air cleaner? Have you removed the cover over the stock air cleaner? Any one of these could cause water to get in the intake and cause problems.
Old Jul 22, 2007 | 11:02 PM
howellrcng's Avatar
howellrcng
no to everything......and I have checked the seal......
Old Jul 23, 2007 | 01:13 AM
Carnac's Avatar
Carnac
Default Could it be...
Could it be that your Traction Control is kicking in. Mine does (z-51 with SC tires) with any amount of water on the road. Really feels like I am losing power and bad throttle response. Try Traction Control off next time (be careful) and see if it runs normally. Cheers - Jim
Old Jul 23, 2007 | 06:56 PM
howellrcng's Avatar
howellrcng
It's not TC brother, it runs like total crap....I mean it won't go 10 mph and spits and sputters til it runs long enough to dry something out then it runs fine.....I will try the TC just to eliminate another possibility, Thanks
Old Jul 25, 2007 | 01:18 AM
Carnac's Avatar
Carnac
Default TC was just a thought...
but it sounds like something more is going on with yours. With the little bit of rain we get in Las Vegas, with it does rain, I can hardly get moving without sliding. Better after a good hard rain (but those are few and far between). Maybe the dealer can find a fault code or duplicate. Cheers - Jim
Old Jul 26, 2007 | 11:01 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
It sounds as if the ignition wires need to be replaced ! But your car is a 07 so that is doubtful good luck
To Runs bad when it rains
