LS2 oil consumption
Old Jul 23, 2007 | 02:44 AM
rokkman's Avatar
rokkman
Default LS2 oil consumption
My 2006 CTSV spun a #5 rod bearing in the first 150 miles. It was rebuilt and doing alright but the last 2 months I have had to add 2 quarts of oil between changes. They are now doing an oil consumption test on it. It has 16k on the motor and while I drive it hard I do not drive it anywhere near as hard as I did my 99 c5. This car has been nothing but problems ( broken motor mount and blown rear diff bearings plus the rebuild) I know I should have kept the vette but I am going thru a divorce and have two kids who out grew riding in the back of the vette. Cadillac gave me the bs bulletin about using a quart every 500 miles in hard driving, but what is the point of having 400 ponies if you can't use them. Any of you have similiar problems?
Old Jul 23, 2007 | 03:00 AM
sallen619's Avatar
sallen619
You must be using Mobil 1...I don't have the same problem as you but, Ive noticed when I drive hard the oil burns faster than normal.
Old Jul 23, 2007 | 03:36 AM
Invisiguard's Avatar
Invisiguard
Im coming up on the third oil change on my 07 and so far Ive consumed 2qts between each oil change too, I dont baby it but I still thought this was a bit high,
Old Jul 23, 2007 | 01:07 PM
codename Bil Doe's Avatar
codename Bil Doe
My LS1 ('01 WS6) consumed about a quart every 1500mi. They're known for eating oil, but the engine was just as strong at 110k mi. as it was at 10k.
Odd, but my 07 C6 is autox'd and driven through the hills hard. 1/2 quart of oil low between oil changes. Doesn't seem to be eating as much, but not uncommon.
Old Jul 24, 2007 | 12:17 PM
djfullshred's Avatar
djfullshred
Between the last change (approx 4,500 miles), mine burned about a 1/2 quart. I am not gentle with her either.
Old Jul 24, 2007 | 01:56 PM
Keaka26's Avatar
Keaka26
I am definitely not easy on my car in most situations, but after 6000 miles on my 07, I've not lost pretty much any oil at all. Just a very small amount during the initial miles while I was breaking it in. Did you cycle your motors through a wide variety of RPM ranges during break-in? As in not maintaining the same engine speed for too long? In my experiences, people who don't take particular care to hit all rpm ranges in the initial miles tend to consume a little more oil than others...
Old Jul 24, 2007 | 02:42 PM
TaylorMade's Avatar
TaylorMade
That's interesting that you say that because my buddy told me the exact same thing. When breaking your car in did you take it over 3k rpms or did you vary your rpms between 1k and 3k.
Old Jul 24, 2007 | 02:48 PM
Keaka26's Avatar
Keaka26
Actually, I had it up to about 6K on the first day. So basically you climb RPMs (not under heavy load for a while) by going up to say 3k and letting the RPMs wind down in gear(engine braking) down to 1.5k and then bring the RPMs up to 3.5k to 4k and wind down again, and then again to 4.5k to 5k etc until you get to 6k or so. Then go ahead and repeat the same procedure again, this time under a little more heavy load. This is why steady speed freeway driving is the worst during break in, because your engine is sitting at the same RPM if you're not careful to vary engine speed through up/down shifting or increasing/decreasing your driving speed.
Hope this helps.
Old Jul 24, 2007 | 02:55 PM
TaylorMade's Avatar
TaylorMade
Hope this helps.
How many miles did you continue this brake in method. I've been told 500 miles and the car is ready to be driven hard.
Old Jul 24, 2007 | 04:32 PM
Keaka26's Avatar
Keaka26
I did indeed continue to do this for the first 500 miles.
Old Jul 24, 2007 | 05:33 PM
dbradley's Avatar
dbradley
First, I find it odd that they "repaired" the engine instead of just putting a short block in its place, especially in a new car. That said, my LS-2 uses zero oil. I changed at 1500 miles to Royal Purple. It now has 6500 miles, still on full. Just drove across country 70-80 and sometimes a "little" more. For the record, I did follow the recommended break in procedure.
Old Jul 24, 2007 | 06:19 PM
carpe dm's Avatar
carpe dm
Rokkman: You have an LS6 engine. I have both a Vette and a CTS-V and have never burned a drop of oil...!? Lucky I guess; of course, I did break them in carefully. Do you have oil in your intake?
Old Jul 24, 2007 | 09:17 PM
BearCreekC6's Avatar
BearCreekC6
Originally Posted by rokkman
........I am going thru a divorce and have two kids who out grew riding in the back of the vette.
Old Jul 24, 2007 | 10:30 PM
fergy flyer's Avatar
fergy flyer
Hope this helps.
I break-in all my motors this very same way except I wait till I have over 100 miles to start. I've always had particularly strong motors and they never have used oil.
I'm doing something different on this car. My car is an 06, and I'm following, to an extent, the oil life monitor. I'm using mobil 1 5-30 in Florida. I changed it at 3600 miles which was 6 months. Then at 6600 which was 1 year from the first oil change. The car then became my daily driver, and I drove 2400 miles before leaving for a 10,000 miles trip around the country. At 15,600 miles I changed it at 45% of oil life, because that was a convenient stop. That was 9,000 miles on that oil change. I now have almost 20,000 miles and it shows 75% oil life. It hasn't used 1 drop of oil. I don't drive hard, but I'm not babying it either.
Old Jul 24, 2007 | 10:53 PM
Charlie M's Avatar
Charlie M
I think I may have been a little hard on my car, but it has not used any oil at all. Kind of hard to push the car real hard all the time as you would not have a drivers license if you drove too hard, and hell the tachometer is not much above 2000 and at 100 mph. Kinda hard to really run one a car like this "Hard"
My dually truck (8.1 + allison + 4.11) used a quart about every 3000 miles pulling trailers, sometimes over 15,000 lb, and I thought that was excessive. I let it go as it was basically a quart between oil changes.
I'd say you have a problem.
I also find it odd that they repaired a blown engine instead of replacing.
Old Jul 24, 2007 | 11:17 PM
rokkman's Avatar
rokkman
Motor was repaired, I have the invoice for the work. The crossmember above the engine states LS2. These cars are 6 speeds so you can get some r's on but they do have a rev limiter.
I am not sure if the face was for the divorce or the kids riding in back but as a kid I rode in the back of my Uncles 63 and still have fond memories of that. The kids would ride in the back of my C5 on the quarter mile trip to the school, never on city streets, then I had them sit side by side in the passenger seat but they grew up too fast. Divorce came along so I bought the next best thing (or so I thought).
I did not take it easy on the break in, I drove it just like the salesman did. Also they made no mention of taking it easy, I guess I should have known better.
Not sure about the oil in the intake, after my 73 vette I quit working on cars, I just want to drive them now. Besides it is too damn hot to work on them in Vegas. I will drive it till the oil light comes on and then see what they have to say.
Old Jul 24, 2007 | 11:32 PM
exukboy's Avatar
exukboy
I broke my 05 vert in nice and steady over 1,500 miles at all different speeds. No lugging, nothing above 3,000 rpms and used the long decending hills and engine compression to slow the car down and help build up oil control. I currently have 11,000 miles on the motor which runs really strong, I don't baby it but am careful about warming up the motor before getting on it. Just completed a leasurely 2,400 mile round trip with no oil consumption at all. I'm using Mobile One. However, if I drive hard it uses a pint every 1,000 miles but if I use Amsoil it uses about a half of a pint per 1,000 miles.
To LS2 oil consumption
Old Jul 24, 2007 | 11:39 PM
exukboy's Avatar
exukboy
Oh yes one more thing, after my 2,400 mile easy round trip, my exhaust tail pipes were still fairly clean which really suprised me. When I drive the car hard on local trips the tips are really sooty. Gotta be burning some oil and I guess when the engine works really hard especially at higher RPM's it's bound to use more oil. Seems normal in my case I suppose.
Old Jul 25, 2007 | 11:03 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
That's not what I want to hear...
Sorry for your problems. I've got an 06 CTS-V which I bought as a used corporate car with 7k miles on the clock. I ran it to 10k on the stock factory fluids and didn't need to add any oil. I changed the oil to the AMSOIL Series 2000 0w30 at the 10k mark and haven't had to add any oil in the 1000 miles or so I have on this oil change either.
Hope you get your problems with the motor sorted out. Best of luck to you!
06 CTS-V has the LS2. Older CTS-Vs have the LS6.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 25, 2007 | 11:51 PM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
I had an 05 V ( LS6 ) and by the time the thing crossed the 20k mark , it was burning oil like a pig , about 2 quarts every thousand miles
Not the same engine , but I feel you pain .....
