Vararam spacer question
Old Jul 25, 2007 | 05:19 PM
  #41
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by SpinMonster
I dont have a VR spacer but on the topic of dyno variances, why is it that none of the dyno tests ever have a loss since the variance can be +/- 5 HP or some number. When guy gets +9rwhp from an UD pulley, the nay sayers point to dyno variances yet I have never seen the -9 HP loss from one.
Has anyone seen a verified loss from a spacer? If it in fact adds nothing and the variance is +/- then shouldnt the occasional dyno test show a loss due to variance?
smarty
Old Jul 25, 2007 | 05:32 PM
  #42
jimman's Avatar
jimman
A while back Magnaflow had an open house with free food and dyno pulls showing off their new X pipe and exhaust system. After a couple of hours with a couple hundred people milling around the selected winner got the new Magna system installed of which they did a before and after, lost 8 rwhp, got real quit around there.
Old Jul 25, 2007 | 05:38 PM
  #43
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
Originally Posted by edv2122
Wow, this thread has really gotten off track. How bout that throttle body spacer?
Maybe those two need to get a room?!
Old Jul 25, 2007 | 06:04 PM
  #44
VetteNo2's Avatar
VetteNo2
Originally Posted by jimman
Without a repeatability test it has no meaning. Every dyno pull I've had done the second and third pulls without doing anything were always higher.
I wouldn't say that it has no meaning.
I would say that it lacks the specific meaning agreed to by people that make such measurements for a living for tests that are proven to be repeatable and reproducible. Then the tests may also may need to be done enough times to generate a big enough sample to support a hypothesis test. The test would have to be done based on agreed to parameters, etc. Of course, we could monkey with the paramaters and rig the test, too.
I would certainly say that it has less meaning than if all of the appropriate work to support a statistically valid test were done. However, for a test of a $70 spacer, I doubt that anyone other than the manufacturer would bother. The expected value of perfect information wouldn't be enough to justify the test. Sometimes when we have to say something but can't afford a truly valid test we just have to be practical, maybe take an everyday risk, and settle for an inconclusive test result that might be a useful indication when combined with unbiased, seasoned reason. Saying that the test has no meaning is not useful in those cases
I have also observed the trend that you mentioned about the second dyno pull being higher. This happened on the one and only dyno session I have ever put my car through. However, the readings were less than 2HP and 2FTLBS apart. I have seen others 5 higher. Perhaps that is why Vararam's quote of LAPD's test results said 4-6HP.
Old Jul 25, 2007 | 07:24 PM
  #45
HITMAN99's Avatar
HITMAN99
Apparently you haven't witnessed many dyno events, if you did you would easily see the point.
How many would one have to attend? I've probably been to a dozen different "dyno days". I dynoed my '99 Camaro over a dozen different times, 3-4 pulls each time (learning from it that it's a good way to fry your cats), my C5 6-7 times, and my C6 only twice. I know the owners of 3 local shops, and have observed many pulls aside from the ones I already mentioned.
Most of the "variance" that I've seen has been between the first and second pulls. IMHO, this is often caused by the carbon built up in the engine by daily driving. You can usually see it shooting out the tailpipe on the first pull. The third pull often drops off because the engine is hotter, and heats up the incoming air. I've also seen cat overtemps cause the ECM to richen the A/F mix to cool off the cats, dropping a few ponies in the process.
Whatever point I was supposed to see escapes me.
My opinion is that the "variance" that is often talked about is between two different dynos from the same manufacturer, not between two different pulls on the same dyno.
Old Jul 25, 2007 | 07:34 PM
  #46
jimman's Avatar
jimman
The point is and didn't think I had to clarify it. You will get normal output HP deltas from consecutive pulls and to say with a single pull the increase was with the addition of a spacer when it probably was do to warmer oil or less carbon you name it. That's why you need to do repeatability tests to see what caused the variance. That is standard test procedures which don’t seem to be adhered to in this industry when people are trying to sell things.
Old Jul 25, 2007 | 07:46 PM
  #47
HITMAN99's Avatar
HITMAN99
So you think Vararam made their claims based on a single pull? I don't think so. To the contrary, I have found their testing to be fairly exhaustive.
Anyway, I can understand why some folks are natural skeptics, and everyone is entitled to their own opinion. Until I see some repeatable test results showing that the spacer doesn't work, I'll stick with MY own opinion.
Old Jul 26, 2007 | 09:04 AM
  #48
RBYCC's Avatar
RBYCC
I think we are addressing "tuning", not manufacturers published claims.
Dyno is just another "tool"
That's why you do multiple "before and after" pulls....
You're not looking at a "hard number" but the relationship to a comparitive number, no more, no less.
If you show a gain, then you prove/confirm it out on the track.
If you show a loss, you reverse what you just did.
Was true forty years ago and still holds true today
Old Jul 26, 2007 | 09:43 AM
  #49
Zig's Avatar
Zig
imo, when using a dyno, one must establish a 'baseline'.
usually, not obtained from one or two pulls. you run her, get her warmed up. she needs to be ridden hard for at least 50 miles before she will even think about being ready. you then, 'baseline' her with back-to-back runs, careful not to make her puke. she needs to be consistent at least 3 out of 5 times.
Old Jul 24, 2011 | 06:52 AM
  #50
Randy_medion's Avatar
Randy_medion
I heard the spacers whistle is that correct?
Old Jul 24, 2011 | 09:30 AM
  #51
dennis50nj's Avatar
dennis50nj
i never heard a whistle, i passed my neighbor and he said he heard a sound like a train or jet coming from behind him, then as i passed he heard like a loud explosion , it scared him, he didnt no i was passing, and i passed him very fast
Old Jul 24, 2011 | 11:09 AM
  #52
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Was that a sonic boom Dennis?
Old Jul 24, 2011 | 12:11 PM
  #53
5knives's Avatar
5knives
Now you guys got me thinking of getting a spacer. I already have a VR and FAST (+ H/C) Am I looking at tuning issues with the addition of the spacer? What kind of fitment issues will I have with the Fast and VR already on?
Old Jul 26, 2011 | 02:03 AM
  #54
5knives's Avatar
5knives
Will a spacer fit on an LS with a FAST and VR without any problems? Also, will I need a retune?
Old Jul 27, 2011 | 12:45 AM
  #55
Mike V.'s Avatar
Mike V.
Default Question, need help
Originally Posted by VaraRam Industries
The TBS was dyno tested for us by LAPD and showed a gain of 4-6 rwhp!!! This was an independent test when we first developed the TBS!!!!
Steve
I am an avid fan of the VR cai & have used my spacer from the orig. install. It's mated to a FAST 90 on an '05 LS2. I have suffered vacuum leaks at the spacer over & over which thows a CEL along w/ the obvious probs of a vac leak. I have tried many variations of the installs, differing torque on fastners, using orange RTV to create gasket (both sides), to name a few. Sooner or later it always seems to come back & leak. I believe there's gain & I want to keep it on, do you have any solutions/suggestions to keep the setup from leaking. Like I mentioned, keep in mind it's mated to a FAST 90.
If you would please, send a PM w/ your thoughts. Thanks in advance.
Old Jul 27, 2011 | 07:28 AM
  #56
dennis50nj's Avatar
dennis50nj
Old Aug 1, 2011 | 01:47 AM
  #57
SoonerC6's Avatar
SoonerC6
Mine leaked as well, but with the stock manifold... So i just took it off. Couldn't tell a difference in power or throttle response, but that's just me.
