Shock removal HEELLPP!
Old Jul 28, 2007 | 03:02 PM
stinky's Avatar
stinky
Default Shock removal HEELLPP!
On my '05 MN6 Z51, for the front shocks I've been trying to utililize the zip-tie method but am unable to get it to compress the shock enough to allow the upper mounting rod to pulled down to remove the shock. I sure as hell don't want to go mechanically beyond this (per maunual)...any suggestions would be appreciated.l
Old Jul 28, 2007 | 03:15 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Originally Posted by stinky
On my '05 MN6, for the front shocks I've been trying to utililize the zip-tie method but am unable to get it to compress the shock enough to allow the upper mounting rod to pulled down to remove the shock. I sure as hell don't want to go mechanically beyond this (per maunual)...any suggestions would be appreciated.l
If you have an extra jackstand or jack you can put it under the lower suspension arm and use the weight of the car to compress it. Hook up you zip ties while it is compressed.
Old Jul 28, 2007 | 03:30 PM
stinky's Avatar
stinky
Yes, I know. I've jacked it up to point the car will start to lift. Used pliers to pull the ties as tight as I could but I'm still 1/2 to 3/4" from getting the upper rod out.
Old Jul 28, 2007 | 03:37 PM
MYVetteBy25's Avatar
MYVetteBy25
You don't need any zip ties. Make sure the suspension is unloaded. After you've removed the upper shock nut, dislodge the bushing from the frame (difficult, but not impossible). Then just use some muscle and push down on the dust boot to compress the shock rod.
Old Jul 28, 2007 | 04:02 PM
stinky's Avatar
stinky
I might be missing something here...by unloading the suspension you mean? Disconnect the sway bar end link?
Appreciate the responses.
Old Jul 28, 2007 | 06:35 PM
drivinfast's Avatar
drivinfast
Default Just did my fornt shocks
I learned from the rear. Unbolted both lower A arm bolts at the frame, unbolted the sway arm from the A arm-push the bolt all the way out, and the whole front just drops down enough to remove the shock out completely with no compressing. obviously unbolting the shock from above and below. then i used a little jack to maneuver the A arm and new shock back into place to put back together. to me its harder than the rear. I did compress the rear shock to remove but that one you can compress easily.
Just posted a question if this A arm removal method affects the alignment, specifically the camber.
Why didn't I think of the ratchet strap method? That would work on the front since it is difficult to compress knuckle wise.
Last edited by drivinfast; Jul 28, 2007 at 11:02 PM. Reason: Concerned about alignment
Old Jul 28, 2007 | 10:49 PM
Modshack's Avatar
Modshack
Default Easy way..
There's an easier way......I just did this on my '08 this past weekend. Do a loop at the top, then use a ratchet strap to collapse the shock. Tried the Zip tie with the same result (not enough collapse) so went this direction and it worked great..... Here's a shot of the rears, but you can do the fronts the same way. Just rig a loop at the top for the strap to run through..
YOu can get a lot of collapse with this method, making the install easy.
Old Jul 28, 2007 | 11:57 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
Use some bailing wire. Does takes two sets of hands, out in seconds. Pre-cut some thin bailling wire (Home Depot). One set of hands compresses the shock, your buddy wraps some wire at the top of the shock, to the bottom of the shock and twists the wire. Shock stays compressed when hands are released. Comes right out, or goes right in. Done.
Old Jul 29, 2007 | 01:16 AM
stinky's Avatar
stinky
Modshack, I'm glad you showed this as it was something I thought would be worth the try but uncertain if it had been done. Where would one get a ratchet strap anyway?
Vettealot, your method is next if the strap thing doesn't do it. Thanks.
Karik, I'm on my own or otherwise I think we might have muscled it out as you did. But thanks for the idea.
Old Jul 29, 2007 | 03:32 AM
1SLOWC6's Avatar
1SLOWC6
I just unbolted the lower control arm then fastened the shock on top after used a floor jack raised it up! my 2 cents
Old Jul 29, 2007 | 11:23 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
If you have the Z51 option, it's almost imposible to compress the shocks by hand. I did mine myself and it took me 4 hours just to do the front. It took 3 hours to to the rear. I used the zip tie method.
Old Jul 29, 2007 | 09:02 PM
drivinfast's Avatar
drivinfast
Same here, . That's why I undid the lower A arms, but If I am correct from another thread, You need to place the notches back where they were, or camber is off from your previous alignment. There are 4 notches, 2 degrees each, so I guessed at 1 deg neg camber = between notch 0 and 2. Thats until I get an alignment and ask the tech there.
Old Jul 30, 2007 | 05:15 PM
99FewteRC5's Avatar
99FewteRC5
instead of unbolting the lower control arm unblot the upper control arm. That way the alignment is not affected.
Old Aug 4, 2007 | 09:02 PM
stinky's Avatar
stinky
Default Modshack----
Your suggestion worked GREAT (once I figured out how to do it) My rears came off easy as hell, compressed by hand and twisted down and out, install was the same. The fronts OMG. Those Z51 shocks will NOT compress, period. After unbolting the top nut and then the 2 lower bolts I got rid of all the zips and with the strap I placed the ratchet about 3" from the top of the shock, ran the strap up and used a half knot around the top of the shaft just below the bushing. I then jacked the suspension up to compress the shock some. Then snaked the length of the strap down and around the bottom of the shock where the encased bushing is, another half knot. I zipped this so that it would not slip up over the shock tube. Fed the strap into the ratchet and a couple of pumps later the shock was compressed and pulled out with no problems. I spent more time looking for heavy duty zips then it took me to remove the shock...the second one took 15 minutes The FSDs compress easily by hand so they go in rather quickly.
Steve, once again, THANKS.
Old Aug 4, 2007 | 10:22 PM
Modshack's Avatar
Modshack
No Problem! Glad it worked for you too....
To Shock removal HEELLPP!
