Yes I did it on my 2007 2lt kit is 900 dollars and gives you everything you need....I Wanted that when I bought my 2007 but I did not want the other junk that went with it..Works like a charm just like stock ...Asab.........
5 - the hardest part is finding the bolts, but if you look hard enough you will find them. The car goes back together very easy. Good as new and the HUD works great.
I just installed a HUD in a 2007 2LT and it works great. Very visible even during daylight and all features work, ie.)g meter, speed, rpm, turn signals. It cost me 700.00 for the kit and did it myself, all in all the install was fairly seamless. I would not recommend if you have not worked on interior and wiring before. If anyone needs help and is near Pensacola send me a message. I'll install for a lot cheaper than a shop will.
