LS2 PCV System Diagram/Photo Needed
Old Jun 29, 2018 | 11:24 PM
mcm95403's Avatar
mcm95403
Originally Posted by Dano523
Part 700 is the line/tube.
https://www.wholesalegmpartsonline.c...archString=pcv
As for accordion connector port piece, don't know if GM sells it alone, but would check with some of the after market vendors for that piece, since some of the after market intake pipes come with it already installed when you buy the part, isntead of reusing the port from the old hose (hence they must have a source for the port part piece).
Worse case, you can buy the entire accordion duct piece with port and clamps, part gm 10334217 for around $26 if you can find one in stock, and it will come with the needed port.
Short of that, if need you spec's to just lathe on up of some Delrin round stock, can give them if needed.
I already bought that accordion piece from the dealer and there were no hose clamps and no tube. I'll keep you in mind for the specs. Thanks again!
