What is CAI
Old Aug 2, 2007 | 04:03 PM
seebobgo's Avatar
seebobgo
Default What is CAI
Just can't figure out this one.
Old Aug 2, 2007 | 04:07 PM
Patman's Avatar
Patman
Cold Air Induction, such as the Vararam unit.
A lot of intake makers misuse this term though. The ones which just use a big open air filter that sits in the hot engine bay, cannot be called cold air induction, IMO. They aren't drawing in cold air at all.
Old Aug 2, 2007 | 04:10 PM
seebobgo's Avatar
seebobgo
I see, said the blind man...thank's_Bob
Old Aug 2, 2007 | 04:14 PM
11secondGP's Avatar
11secondGP
then its a HAI or open cone
Old Aug 2, 2007 | 04:28 PM
Myhardtop's Avatar
0Myhardtop
Former Vendor
Yeah, but you add the Vette-Air, then what?
We've used the Vette-air we great success. Don't know who Vette-Air is? Check the website below, see which system has achieved fast times.
I speak the truth…can the rest handle the truth?
www.vette-air.com
Thanks,
Carlos
Old Aug 2, 2007 | 04:33 PM
Fast Fun's Avatar
Fast Fun
Can it not be said that when the car is moving forward, it's getting basically the same air thru the grill and from underneath that a Vararam get's but without the ram effect? So maybe a Vararam should be a RCAI or Rammed Cold Air Induction.
Alhtough......come to think of it, the term Cold Air is also subject to interpretation. It really should be Outside Air Induction, which if rammed, would be of ROAI
Just tryin' to keep the conversation lively.
Old Aug 3, 2007 | 05:23 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Aug 3, 2007 | 08:04 AM
Fast Fun's Avatar
Fast Fun
Default Yes...but...
Originally Posted by seebobgo
ROCAI on cold days and ROWAI on warm days
Good point, but at what temperature does cold become warm.....plus.....what about hot days? I think we need a hot setting too, now to be known as ROHAI.
Old Aug 3, 2007 | 10:36 AM
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
You know with this cold air intake business I always wondered why general motors does not do this from the factory. Almost everyone puts in a CAI kit and different exhaust. More air in, more exhaust out. I just can't figure out why they don't do it up front. Seems it would be less costly if they did it as a standard feature than all of us going after market to get it done. Go figure
Old Aug 3, 2007 | 10:43 AM
Patman's Avatar
Patman
The main reason they don't do it is because of the increased risk of hydrolock if someone drove through a deep puddle. The average person isn't smart enough to avoid super deep puddles, but those of us with Vararams and other similar systems are smart enough to slow right down when driving through deep standing water and if we know the front end is going to be completely submerged, we would completely avoid it. You'd be surprised how many people out there aren't smart enough to know this, and think that they can drive their car in 2 feet of water.
Old Aug 3, 2007 | 11:02 AM
Bumpstick's Avatar
Bumpstick
Read the info on this link.
http://secure-order-server.net/caull...=6270663_19055
This works and no fear of Hydrolock
Old Aug 4, 2007 | 01:16 PM
WFO's Avatar
WFO
IMhO...any air temp below engine operating temp is cold air. The colder the better is the ultimate objective.
It's more about Marketing termonolgy of an aftermarket product. Whether the breather source is from oem airbox, forced, ram, turbo, intercooled whatever...it's all cold air. The changes might be design of air flow methodology and filter element/ placment.
Design "theory" plays huge in CAI with enviornmental conditions being the conundrum. Some brands do better than others in the rain/humid areas while others are better in more arrid enviorns. User data in one's area speaks volumes towards a products success/failures.
Old Aug 4, 2007 | 02:05 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Bob,
Cold Air Induction.
As delivered from the factory the Vette air intake is within the engine compartment (ie Hot Air)
The CAI draws air from outside the engine compartment. Maybe not Cold, but a heck of a lot cooler than what's inside.
Cold air is more dense (read that as more O2) and burns mo betta resulting in more RHWP & TQ.
Old Aug 4, 2007 | 07:57 PM
Myhardtop's Avatar
0Myhardtop
Former Vendor
Originally Posted by JFTaylor
Bob,
Cold Air Induction.
The Vette-Air scoop shields all engine bay and radiator cavity hot air. The scoop faces forward, it mounts up high and the opening lines up with the end of bumber support (no HOT air ingestion).
Thanks,
Carlos
Old Aug 4, 2007 | 09:41 PM
Patman's Avatar
Patman
Today I proved one of the reasons why the Vararam works so well, it lowers the IAT very quickly. It was about 85 degrees here, and we were playing around in HP Tuners, and with the engine shut off hot, my IAT would spike up to 140 degrees! But within about a minute's worth of driving, it would be down around 90 degrees or so, thanks to the Vararam!
Old Aug 5, 2007 | 12:24 PM
Myhardtop's Avatar
0Myhardtop
Former Vendor
You are right Mr. Patman.
The Vette-Air does the same thing but a little sooner since the air travel distance is not as long. So yes, getting outiside air does help!
Thanks,
Carlos
Old Aug 5, 2007 | 12:41 PM
Patman's Avatar
Patman
Thanks,
Carlos
Yep, not to single out Vararam, but any good cold air induction system will do wonders for lowering the IAT very quickly on these engines. It's amazing how quickly the IAT rises due to heat soak, once you shut off the engine. And so you want it to drop down as quickly as you can.
To What is CAI
