Anyone With C6 Start Problem
Old Aug 3, 2007 | 10:03 PM
Comfortably Numb's Avatar
Comfortably Numb
Default Anyone With C6 Start Problem
On occasion I have gotten a green light, pushed the start button and nothing, car does not turn over. Takes about 4-5 tries ie., tonight. Anyone else have this? I'm sure taking it to the dealer is not good because it does not happen every time.
Old Aug 4, 2007 | 02:57 AM
joela's Avatar
joela
more detail on your profile or your mods would help.
Old Aug 4, 2007 | 07:07 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Are you sure you have your clutch pushed all the way in? Sometimes that's been my problem.
Do you have a Window Valet?
Old Aug 4, 2007 | 08:52 AM
VET4LES's Avatar
VET4LES
Old Aug 4, 2007 | 08:57 AM
Comfortably Numb
Mods on the car are zero - no window valet. I've had DBS problems with this car. They have been corrected with the 11/2006 flash that GM performed (battery holds up much better). Ignition light is green/battery was @ 13.8. Don't know what else to say. I'm not sure this corrected things but the car was in reverse, I re-shifted to reverse, pushed the button several times, re-shifted to revers and finally got it to turn over.
Old Aug 5, 2007 | 01:00 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Did you pump the clutch? Sounds like a clutch switch out of adjustment, since moving to and from reverse would normally work the clutch.
Old Aug 5, 2007 | 06:42 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
To Anyone With C6 Start Problem
