Headers
Old Aug 5, 2007 | 08:56 PM
rocket1's Avatar
rocket1
Default Headers
Installing Kooks LT's and cats Tuesday in my C6 Z51.
Are there any heat related concerns I should address such as plug wires, starter etc. As always any advice is appreciated!
Old Aug 5, 2007 | 09:27 PM
toro1966's Avatar
toro1966
None. Just make sure you route the O2 extensions away from the headers. Other than that, everything fits in good and you shouldn't have any issues. Good luck and cheers!
Old Aug 5, 2007 | 09:35 PM
Stinger !!'s Avatar
Stinger !!
Might want to consider changing out the OE tunnel plate (cheap galvanized sheet steel) at the same time for a thicker ceramic coated one...big reduction in console/interior heat radiating through the floor and console...heres a link...
http://forums.corvetteforum.com/show....php?t=1770048
Old Aug 5, 2007 | 09:47 PM
rocket1's Avatar
rocket1
Default Headers
Thanks for the replies.
The tunnel plate might be a good idea.
The console already gets very hot so I will look into it.
Old Aug 5, 2007 | 10:34 PM
cdn651's Avatar
cdn651
The tunnel plate was one of the best mods I made. Cuts heat in the console alot. Still warm but before it was an oven.
Old Aug 6, 2007 | 12:33 AM
TRJ's Avatar
TRJ
Another mod that makes sense is the ceramic coated, stainless steel "starter heat shield." Made by Lingenfelters...
Old Aug 6, 2007 | 12:51 AM
71stang99's Avatar
71stang99
Also think about 'socks' for wiring around the headers, not an absolute as I dont have them but other recommend them.
If you keep the stock tunnel plate my car had a hole drilled so that the wires for the kooks were fed above the tunnel plate and dropped through the hole to the rear o2 sensors.
Hight temp nylon ties are good for keeping wires away from the heat.
Again I kept the stocker tunnel plate and yes its warm however living in Southern Nevada with really hot temperatures the AC keeps the car plenty cool and its not like its hot enought to bake a potato.
To Headers
