Coolant system problem
Old Aug 8, 2007 | 09:12 AM
Gman57's Avatar
Gman57
Default Coolant system problem
I just had some major mods done along with 160* stat. I drove all the way home..... 300 + mi. at 70-80 mph with 90 deg outside temps and coolant temps at 175-180*
The next day with 90*+ temp I was out pushing it a bit harder on some near by country roads and the cooling system not going much over 205*. Got back in town and made a stop with the car still running for less than 10 minuts and the temps got to 240-245* and started out the spill tube.
After getting it cooled down and adding new coolant that I lost. I did a test run on the road for an easy 10-15 miles and letting it idle 2 different times for 15 minuts at 85* OD temps and it stays in the 180-185* coolant temp range.
My Question is?
Should I look at changing the stat out now just to be safe, could it have been an air pocket after all this drive time on it or do I just keep an eye on it for awhile.
At what temps does the fan come on stock and if it has a tune on it for the 160* stat what should it be set at .
Old Aug 8, 2007 | 09:36 AM
dennis50nj's Avatar
dennis50nj
My Question is?
i think its an air pocket. after a few full heat ups then cool downs, it will be fine. keep it full
Old Aug 8, 2007 | 09:39 AM
6Speeder's Avatar
6Speeder
Sounds like you haven't reset the fan to come on sooner and at higher percentages. You really need to if you want full benefit of the 160. I put mine at 15% @ 192, ramping up to 90% by 198. It doesn't ever get over 205 now.
Old Aug 8, 2007 | 09:43 AM
Miaugi's Avatar
Miaugi
with both of these posts...your problem was likely air in the system in the first place, and having the fan on temps would be a good idea.
To Coolant system problem
