Weight Reduction for a c6
Battery relocation doesn't typically reduce weight (it can actually add weight due the added length of cables and wiring) but it does help shift it back which helps in drag racing, road racing and safety.
A lightweight battery (I had one in my Z28 for a while) in the stock location can save up to 22 pounds off the nose alone.
Lightweight seats and/or removal of passenger seat.
Magnesium or carbon fiber rims (skinny ones up front if drag racing)
Non runflat tires
Remove front sway bar (again for drag racing duty only)
Titanium exhaust (or none at all)
Carbon fiber hood and other body panels
Lexan windows
Removing the air bags and stereo system (along with the A/C and carpets/sound deadening mentioned above)
It will not be easy (nor inexpensive
) to get the car down to 2800 pounds without really cutting it up but it is possible.
Non runflat tires
Lexan windows
the biggest non invasive weight removal will be racing seats and lightweight battery, those items could save you close to 100LB. You can save around 30LB with two piece rotors.
But, you can get the Hawker Genesis or Odyssey lightweight batteries and those ARE lighter.
But be careful if you have a full stereo/DVD system and/or an underdrive pulley in the car with these tiny batteries, could mess with the charging system a bit.
, me included. Exhaust, headers, intake, Oddyssey battery, no air bags (including changing the steering wheel), carbon fiber seats, and lexan windshields are all typical measures to reduce weight. An Elise can get well under 2000 lbs
https://s.p10.hostingprod.com/@www.v...23d56102f220b5
The Dynabatt is almost identical to the ones I'd mentioned above, that's a great way to save some weight on a budget.
A little less costly is this battery: http://www.gotbatteries.com/Productp...ctNum=37L105S1
