LS6 cam in a LS2
I went with a G5x3, biggest cam you can put in without flycutting. So keep that in mind when you hear my opinion. :lol
It's pretty easy to swap cams without having to change out springs. Most people should be able to swap cams in 5 to 6 hours total. So, for $220 and 6 hours of your time you can pick up 20 hp and that is darn good.
What would you suggest if you don't want a head bobbling cam? 20hp more, for a couple hundred bucks more than you might pay for a nice CAI that got you 4 more ponies
Just a guess but instead of an LS6 cam could you get a low lift comp cam with larger duration than an LS6 and not change the springs? What about comp cams 218/224 114LSA with only 0.525 lift? Very mild lift and little overlap but i think this would still be better than an LS6. Would you need to change the springs?
The average person would spend at least 10 hours on the and sure the cam is cheap but you still need, gaskets, oil, filter, dexcool, crank bolt etc.. Now your talking a possible 20 HP for $400.
You are right about the warranty though, the dealer would never know.
It took me 10 hours to do the swap, but I must have spent 3 hours on the darn springs and at least 2 hours getting the oil pump pick-up tube in place (I went with the double roller timing chain and it was a pain, I kept pinching the oil pump tube o-ring). As far as gaskets, they are reusable on the front of the motor, you are right though, you do need a new crank bolt, but that's really cheap. You don't have to take off the intake manifold or the heads. It's pretty straight forward. One caveat, I didn't have to move the steering rack over with the Camaro. Not sure how long that takes.
But, overall, take the oil tube and springs out of it and it's so easy:
Move the rack, take off the front balancer (not hard if you have a good three jaw puller)
Take off the water pump and front cam cover
Take off the cam gear and timing chain
Spin the cam and then insert some 5/16" diameter rods to hold up the lifters
Pull out the old cam, lube up the new cam and reinstall
Only trick on going back together is to use a longer crank bolt to help pull the balancer on. Tighten it down with the new bolt and then use a breaker bar with the handle from your floor jack over the end and twist it another 120 degrees. You really have to grab it and growl, but a long cheater bar helps.
So, I still believe you are only talkng about a $220 camshaft and another $15 for a crank bolt. The gaskets are reusable. The LS engines are really slick.
So, if someone wants to do this in the Phoenix area, I'll come over and help. Or you can come by and we'll do it in my garage.
Everyone says almost no horsepower, but it's probably good for at least 15 hp. That's worth it to me for $235 (cam & bolt). Go to almost any other aftermarket cam and now you have to add $300 for some decent springs and I hated changing those out. I used the top dead center method and the "Larry" tool. If I had to do it again, I'd spring for the Crane tool.
Thanks,
Glenn
Thanks,
Glenn
