Cooling Problem after mods????
Old Aug 14, 2007 | 01:28 AM
ToSlowForU's Avatar
ToSlowForU
Before you spend that much let me ask you, what is your voltage at while driving and at idle?
Old Aug 14, 2007 | 05:43 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
what's your a/f ratio. running too lean will/can cause higher temps.
you may need to step up to a larger rad., depends upon how aggressive you were with the h/c mods.
do you have headers? any wrap or thermal barrier on them?
Old Aug 14, 2007 | 11:24 AM
sheesnaz's Avatar
sheesnaz
Car is charging at about 13 volts on my radar detector. I did a very mild cam, 222/226 574 110LSA, my heads are just 317 truck heads that have been worked by trevor johnson. I do have headers but never had a problem before the H/C. I am really hoping that it was a problem with using the wrong head gasket. I will have to wait until Fri. to find out since that was the fastest Cometic could get me a set.
Old Aug 14, 2007 | 06:47 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
supercharger here!! car is hot as hell when stopping, my tuner said that's normal because of the mods.
