I just purchased this beautiful car last week and now the check engine light is on. I had the code scanned today at a car parts store and the code said "Secondary Air Injection System Fault". I asked what that meant and they said "The air injection system is monitored for faults." I don't even know what an air injection system is, nor how it can be faulting. Does anyone ideas or similar problems on how to fix this or what it means?
One of your check valves are probably rusted closed or you air pump is not working the check valves are locate on the exhaust manifolds. Post in the c5 section for more info. C6's don't have them.
I concure, you're in the big boy's section, why don't you go back and play with the other puppies, where you belong.
I told you brother, you're in pharmeceutical sales (or something like that...), you should have the flow for a C6. I blame your close friend Adam for not "selling" you on the benefits of stepping up to a C6. All his fault, none of this would be happening. You'd be out cruising with him, side by side, not 3 car lengths behind.
Ok, I got it out of my system. You're still cool, I guess.
