Just today, in 97 degrees, and after sitting for lunch for 3 hours and then starting it up, no air for almost 2 minutes! then it was not cold but just COOL, SORT OF! Wrong Answer! Got an aptmt to go back to the dealer on Thursday afternoon after i let the car sit outside in the dang hear for 2-3 hrs to REPLICATE today's situation, for crying out loud,!
And i was told this system is not the same as in my '99 Riviera! Too bad, it should be- maybe I wouldn't be having these problems now! Had my compressor changed one time in 8 years by the dealer-and they gave me a lifetime warranty to boot in the Riviera!
Anyway, we'll see how this works out on Thursday...
If you cut your lunch time to 30 to 45 minuets the A/C might work better.
My wifes 05 acted the same way....we adjusted the freon & replaced the outside air temp sensor to fix it.
We are close & are a full service AC shop, stop by & we will check it for free & make sure the right amount of freon is in it.
Thanks guys but you already dyno'd my car 4 different times! Each time I changed something major I had to re-dyno the car and Ryan was the man-at the time. Personally, I'm sorry to see him go. He did my car just fine. But thanks for the offer but this is a warrenty situation and I'm not letting up for one minute till they get it right or deny warrenty coverage for some reason out in left field. All the work you guys did for me I do not believe modified my A/C system and should not be denied. We will see tomorrow when I go back.
Since YOU brought it up- my "lunchdate" and exgirlfriend had just purchased a 2004 C5 black on black vert and offered a ride in her newly purchased vette. How on earth could I turn the lady down, I ask you! That's why lunch took 2-3 hours! Now my secrets out, thanks to you! Man, you guys, gotta dig into everything! Nothing but nothing is sacred, whew!
I was driving from my lunchdate today-a different exgirlfriend than yesterday, A/C blowing cold when all of a sudden the air started blowing warm! the the fan started slowing down, sped up and started blowing cooler then warmer! Damn thing is possessed!
Well, tomorrow is my appointment at the dealer, I swear, this thing BETTER replicate itself and act up or I will be pi$$ed off! We'll see. I'll post the conclusion to this twilite zone story when its over.
OK, THIS IS IT! STRAIGHT FROM THE HORSE'S MOUTH! The first thing the service writer asked was where did I keep the a/c button, on Fresh Air or Recirculate? I asked what in the world was he talking about??? I just pushed the a/c on and set the temp to 74, considering it was 94-97 outside, I figured that was low enough to get things going. Then he says, Did I read the Book? What Book? I said back. The Owner's Manual! Sure I did, two and half years ago! Now i just push the a/c switch on with it already set on 74 and that's it! WRONG ANSWER!
What I was supposed to do is set the temp at 60 degrees, hit the recirculate push button but NOT set the fan switch on high but on medium to medium-to-low position. GUESS WHAT??? IT'S WORKS!!! SO FAR, ANYWAY! FOR THE LAST 2 TIMES IT DID. I'LL GIVE IT ANOTHER 2 WEEKS AND GIVE Y'ALL ONE LAST REPORT ON THIS.
Thanks for all your technical support and all, guys, you're all great! I can't wait to go back and tell them to check their TSB book for the one that refers to the removal of excess of PHFFTS of freeon.
If that aint a classic, I don't know what is-
I got the same response from my dealer, only the talk came out of this end.
Thank God for the forum. I reduced my charge and the problem was solved. Thanks everyone.
The system is experiencing a high head pressure situation. The engine control module will disengage the compressor clutch at pressures above 300 kPa (435 psi) for safety. Any time the compressor is off, the HVAC control head will return the system to outside air from recirculation mode to reduce interior cabin noise, unless the customer has manually selected recirculation mode. The sound level difference is often mistaken for a change in blower speed.
This condition is most likely seen on a hot engine re-start such as after a gas station stop, prolonged low speed driving, or vehicle idling at an elevated ambient condition. The initial spike in head pressure may be enough to disengage the compressor clutch. If the vehicle has any forward motion, the system will recover within seconds. If the vehicle is stationary or in a significant tail wind, the system can take minutes to recover after a disengagement
After verifying that the vehicle's refrigerant pressure sensor is working properly, the solution is to reduce the refrigerant charge level from 0.64 kg (1.4 lbs.) to a new charge of 0.50 kg (1.10 lbs).
I live in Las Vegas (HOT). My 05 C6's A/C has been great with one exception. I was driving south on I15 from Nellis towards town about noon for a doctors apt. My outside air temp showed 113. About 2 miles from my exit, traffic stopped due to an accident. Sat/crept along for the next 45 minutes. I was sitting there being grateful for the great A/C when the hot air started blowing. Had to shut down the A/C and open the windows. After the doctors apt and moving along at speed the A/C came back and has worked great since. High pressure is what I assumed due to the high outside air temp and no movement on the road.
My question - if I have the R-134 reduced to 1.1# (or let out a bit myself) will the A/C work less well when not in extreme heat that causes high pressure switch to turn off the compressor?
I think it will and will probably leave well enough alone and hope to not get stuck in traffic at 100 degrees +, so I think I will leave well enough alone.
In response to some of the posts above - I think that if you have digital climate control, you should not have to select 60 degrees and no-recirculation for a while and then set another temp later down the road. I set 72 or 74 and get quick cooling and a comfortable cabin temp for the rest of the trip.
Here in Havasu my A/C works fine all the time with less freon. However, we don't have much in the way of rush hour traffic here.
The easy way out is to let out a small amount of freon on your own, then see if it ever happens again. I let out two short PHFFTs and the problem went away. Only months later when I brought the car in for other reasons, did I have the dealer do the official TSB.
Hoonose and Zl-1, thanks for this post. I had this problem for the first time this week (I rarely have my top up or ac on but did this week and had the problem). Took this post to my dealer, they did exactly as the notice said, no arguments, and it works great now.
