I have a 07 C6 base model and want to upgrade my brake pads. A GM dealer told me that the C5 standard pads were ceramic and were a step up from the standard C6 pads. Is this true? If they are ceramic, how would you rate compare them with lets say Hawk ceramic pads.
The GM part number for the pads I received were AC Delco DuraStop 88909667 and 88909668.
Depends on who you talk to. I have the ceramic pads because I don't like cleaning my wheels every day. Some say that ceramic pads don't stop as well. All I can say is that they work well for me.
depends on what you mean by "upgrade your brake pads" ....
Ceremic will produce less dust and likely less squeal and should be fine for normal daily driving ...
If you do a fair amount of spirited high performance driving they will fade faster and they won't give you the bite of a good performance pad like the stock ones will ...
Then, there are street /track combo pads that are a step up from stock for HPDEs ...
I guess because I upgraded to Baer DecelaRotors, Stop-tech brake lines , I thought the ceramic pads would be a step up from the stock pads as far as better braking goes, less dust and less squealing. Sometimes the forum can be very confusing as far as opinions go, thus my question.
According to the forum GM Dealer I bought these C5 pads from told me they are ceramic. Looking at my C6 base pads and the C5 pads they sent me, they seem to be different as far as the material on the pads. There are specs of gold looking particles within the pad, not on the C6 base pads. The dealer told me they sold hundreds of these C5 pads to C6 owners as a step up from the base C6 pads.
Paul,
I'm sure they were cheaper than Hawk Ceramics! I run Hawk ceramics for street use and don't notice any difference in daily driving. I swap out for track use.
I even now run Hawk ceramics with my Z06 brake conversion.
ceramics brake just as good a carbon ones. the problem is they don't brake well with multiple heavy braking in a short amount of time. try it.. go out with your ceramic brakes and hit em hard ! at 60 mph down to 10 mph then speed back up and do it again and hit your brakes...fade!
but thats not normal driving and most people rarely have to do multiple emergency braking, so ceramics are nice and very clean and they last a long fricken' time!
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
True or False, they were not cheap.
It is true and False
The Ceramics or any brake pad for a C5 will fit the regular C6.....True
The Ceramics are an upgrade...They are an upgrade if you want less dust and are willing to compromise on track performance....True
They are not an upgrade if you want better performance IE repeated heavy stops. like track or autox use. Ceramic pads are the last thing you want for that type of duty.
I use Hawk HP Plus on my '06 C6 Z51 MN6. Better braking than stock. I do track days once or twice a month. They do squeal sometimes on the street. But I don't mind.
Yup ... the ceremic pads don't go with the improved rotors and stoptech brake lines - those would be more for improved higher performance braking ... your stock pads would be better for performance than the ceremics you bought ...
I have the Porterfield R4S pads which will give you a step up in performance AND produce less dust BUT they will squeal in street applications ...
I have heard the C5Z pads might be a good choice for what you might be seeking ....
but you are NOT going to get All of the following - LESS DUST, Improved Braking performance, and NO SQUEAL ...from one pad type ...
I just bought these pads to go with new AC Delco D/S rotors. I havent installed yet though.
So, how did the pads work out for you with your set up back then?
