power seat dead
Old Aug 20, 2007 | 05:29 PM
tiger33's Avatar
tiger33
Default power seat dead
today my driver side power seat died. Buttons on seat Nothing. Shut car off seat does not retract. Help. Sounds like a fuse maybe but where is that?
Old Aug 20, 2007 | 06:25 PM
martinblank's Avatar
martinblank
Happened to me too with my '05, it turned out to be the button/ switch itself, which needed to be replaced. In '05 the problem was turning up a lot on the Forum. Dealer replaced it under warranty, no problems since.
Good luck with the fix.
Old Aug 20, 2007 | 10:03 PM
Vette_DD's Avatar
Vette_DD
Does your C6 also have the passenger power seat? If so, check to see if the power to it has gone out. The power for both seats is on the same fuse in the instrument panel fuse block on the passenger's side of the vehicle, under the toe-board.
When you're looking at that fuse block, it will be the topmost fuse on the last row of fuses on the right side of the fuse block. In the owner's manual, it's labeled as "PWR SEATS MEMORY SEATS", but it may not be labeled exactly that way on the fuse block itself.
Old Aug 21, 2007 | 12:16 AM
CessnaDriver's Avatar
CessnaDriver
Check the connector under the seat, might be hard though if you cant move the seat.
To power seat dead
