GM high performance oil pump
Old Aug 22, 2007 | 09:43 PM
oneblackvette's Avatar
oneblackvette
Default GM high performance oil pump
Those running GM's HP oil pump are you using the red high presure spring or the white standard presure spring which makes it a high volume pump?
Old Aug 23, 2007 | 09:44 AM
Bville-Bud's Avatar
Bville-Bud
St. Jude Donor '05-'06-'07-'08
Check over at LS1tech, I am sure I remember reading where someone installed the wrong spring and had to tear it out. I think the issue may have been too much pressure evacuating all of the oil from the pan (if that is possible); PLEASE don't take this as gospel, do the search.
Old Aug 24, 2007 | 05:57 PM
oneblackvette
Red is for high presure if you have changed the crank or added things like a larger cooler to the system.
White is for standard presure and high volume. Good for stock cranks, moves more oil and cools better.
So says GM...........
To GM high performance oil pump
