NPP Question
I installed the 08 NPP mufflers on my 07 and think this is really cool. Tips look good, quiet during cruise, and holy cow sound when the go pedal is pressed.
I just used manifold vacuum to operate the mufflers & this was the tricky part of the install. The mufflers themselves were bolt-in as the pipes are identical 2.5".
While the NPP mufflers themselves should bolt right in to an 08, you will still need to find a way to get vacuum to them. Not sure if your 08 would have any unused piping to the back or if you would need to fabricate your own line.
Looks like I will be adding the NPP as a last minute option. My delima is how to give a positive spin of the NPP option to my wife. Giving her the extra 6HP or cool muscle car sound excuse will not work.
I was thinking just telling her the truth. It will save me gas because of less restriction on exhaust. Also that it extend the engine life since it does not have to work so hard.
Just in gas savings alone I can recoup the cost in 2-3 years.
What do you think?
What do you think?
You crack me up...
I would just tell her you want it and thats that.... yeah, that will work out ok.....
Really there is no reason to get it unless you want it a little louder when you rev it up. 6hp is all hype, I doubt that there is any gain, just good GM marketing.
I dyno'd my ls2 before and after the bi mode exhaust mod that I did and there was No gain at all, just sounds cooler and I have a trick open and close system.
To the OP, yes you can add the npp after the fact and add it to any c6 and still get full control and use of it, just not with the gm valve controller, you have to go aftermarket.
