Guess my horsepower
Old Aug 28, 2007 | 06:51 PM
yellowc6ohio's Avatar
yellowc6ohio
Default Guess my horsepower
guess my horsepower and win nothing
2005 Corvette C6 Z-51 6-Speed 30,000 miles
What I have done to the car
Vararam and Throttle body spacer – $390 for both shipped
Ported intake manifold - $225
Port and Polished throttle body – Free I did it myself
Removed cats $50 for replacements so I could get the flange, sold cats for $70
Straight pipe $10
Removed MAF screen – Free
Spark plugs Denso Iridium IT20 1 step colder indexed - $50
Heat shielding around upper radiator hose – Free
Royal Purple in transmission $30
Drained 1 gal of coolant and replaced it with 1 gal of distilled water and 2 bottles of redline water wetter to help the thermal efficiency. The car still has the stock thermostat. Cruising the car runs 192-194 degrees
Amsoil oil and filter
Catch can $20 each. one on PCV and one on FAT
Doubled stock tunnel plates $20
Magnetic drain plug $10
Optima yellow top
Oil cooler 11” x 5 ¾” x 1 ½ “ 130-70264 from JEGS $63
(still using stock oil cooler as well) Fittings and lines $10
Yes it still has the stock exhaust manifolds and stock exhaust.
Have spent about $700 in performance plus $530 for the tune and dyno time.
what kind of horsepower do you think i will put down to the rear wheels
to make things easier on a dynojet with 12.8-12.9 A/F
Old Aug 28, 2007 | 06:56 PM
timd38's Avatar
timd38
Not enough. Horsepower is like garage space, you never have enough.
The Optima Yellow Top is good for 10-12 HP alone.........
Old Aug 28, 2007 | 07:19 PM
Vetteinplano's Avatar
Vetteinplano
365 or 385 or 405 .....
Old Aug 28, 2007 | 07:22 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
370?
runutzzzzz's Avatar
runutzzzzz
OHHH it's a LS2... 199.... If it was a LS3 515
But really 375?
Old Aug 28, 2007 | 07:42 PM
marct6444's Avatar
marct6444
St. Jude Donor '07-'08
I will guess 372. When will we see the graph with the info???
Old Aug 28, 2007 | 08:24 PM
dennis50nj's Avatar
dennis50nj
366 rwhp
Old Aug 28, 2007 | 09:44 PM
blue racer c6's Avatar
blue racer c6
Straight pipe $10
Optima yellow top
Spark plugs Denso Iridium IT20 1 step colder indexed - $50 You need to look at there web site the lower there # on plug the hotter the plug. Hope this helps. Bill B
Old Aug 28, 2007 | 09:46 PM
runutzzzzz's Avatar
runutzzzzz
If you installed Pulstar plugs add 29RWHP
Old Aug 28, 2007 | 10:10 PM
Fore58's Avatar
Fore58
371 rwhp.
thx007's Avatar
thx007
BWAHAHAHAHAAH!!
Old Aug 28, 2007 | 10:19 PM
johnodrake's Avatar
johnodrake
Moderator
I'm going with 370.
350 Stock, 10 for a tune and 10 for the mods.
Old Aug 29, 2007 | 12:01 AM
glennhl's Avatar
glennhl
345 stock, 10 for the mods (mainly the ported intake & tune): 355 total.
Old Aug 29, 2007 | 12:12 AM
yellowc6ohio
ok here it is
351 hp bone stock – dyno jet
367 untuned 13.5 A/F on RX7 stores brand new in ground dynojet.
377 hp 357 tq tuned 12.9 A/F 23.5 degrees of timing on RX7 store dynojet by Rob LaSota
After data logging it at Mid-Ohio I detected some knock so I took it back and without changing the tune it put down 398 RWHP uncorrected.
SAE corrected it made 390
Made 4 pulls 2 were 389 hp and 2 were 390 hp. Done pretty much back to back.
87.87 degrees outside temp
29.25 in-Hg
24% humidity
1.02 SAE
Full smoothing
Only thing that was different was I changed my Fresh Air Tube from having a breather to putting it back to stock (connected to the intake) but with a catch can. I also added an oil cooler and switched to amsoil.
390 RWHP 365 Ft/lb Torque for $1200 including a tune.
Old Aug 29, 2007 | 12:18 AM
glennhl's Avatar
glennhl
That is stout for the minor perf mods you did! Great job!!!!
Old Aug 29, 2007 | 11:38 AM
rocdom's Avatar
rocdom
6th Gear
Default confused
sorry if this sounds extreamly stupid but I thaught the 2005 came with 400 hp stock?
Old Aug 29, 2007 | 11:47 AM
yellowc6ohio
400 HP stock to the motor which with a 15% drivetrain loss is 340 HP to the wheels. if you want to go by motor horsepower mine is making 460 HP to the motor
To Guess my horsepower
Old Aug 29, 2007 | 01:24 PM
rocdom's Avatar
rocdom
6th Gear
Thank you for the info. Guess that's why I was told after my mods that I was producing 460hp and 475 lbs of torque. New to the site and a very new to vette mods but i know that the speed shop made my car VERY fast. Thanks again
Old Aug 29, 2007 | 02:17 PM
Fore58's Avatar
Fore58
I guess that I just wasted $1800 for headers, with less horsepower. 390rwhp without headers.
Old Aug 29, 2007 | 08:12 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
I'm going to guess somewhere in the neighborhood of 389-390+ rwhp and 364-365+ lb/ft of torque...am I close?
