anybody remove screen on maf sensor
Old Sep 1, 2007 | 12:30 PM
VETTAMOUS's Avatar
VETTAMOUS
St. Jude Donor '11-'12, '14
Default anybody remove screen on maf sensor
installing var ram looking at the maf and wondering if i should remove screen for more airflow. wondering the good and bad of doing this. need help from the pros.
Old Sep 1, 2007 | 12:43 PM
toro1966's Avatar
toro1966
DO NOT REMOVE SCREEN!!! Ok, maybe that is a little strong, but nonetheless, I stand by it. There have been some bad stories about people removing the screen. For two main reasons:
1. And this is the most important - you could end up with debris through it. Anything that gets sucked in through the VRAM would end up right in the intake!
2. The air flow is disrupted. The car will not run the same and in some instances, notably different - rougher.
Just my .02. Cheers!
Old Sep 1, 2007 | 12:49 PM
REVAK's Avatar
REVAK
There has been much debate on this mod, do a search to review the info. I personslly have removed the maf screens on ALL of my LS1 and LS2 maf's [ 4 ] It is recommended to adj. the LTFT's afterward with a predator or another tuner.
Old Sep 1, 2007 | 01:30 PM
carpe dm's Avatar
carpe dm
Not worth the effort or the possible consequences!
Old Sep 1, 2007 | 01:37 PM
VETTAMOUS's Avatar
VETTAMOUS
im getting same response on general forum. i think ill leave it in. thanks ray
Old Sep 1, 2007 | 02:59 PM
PapaTango's Avatar
PapaTango
I removed mine 20,000+ miles ago and have never had any issues. Currently using a Halltech intake.
Just food for thought...some think that the screen does not impede airflow. I'm no engineer but the total surface area of the screen when it is compressed will cover about 25% of the amount of the MAF opening. The total surface area of the screen has got to offer at least some resistance to airflow.
Old Sep 1, 2007 | 03:57 PM
Silver05GTO's Avatar
Silver05GTO
I've asked countless times for before/after dyno sheet to see if anyone advocating removing the screen has seen gains.........noone has ever posted a sheet. Keep the screen.
Old Sep 1, 2007 | 03:59 PM
toro1966's Avatar
toro1966
You are correct, the screen does indeed provide some resistance as opposed to with it removed. The problem here is that the screen also acts to even out the air flow. Not having it disrupts the airflow. I know that sounds bass-ackwards, but that is how it works. Again, it might not be that bad, but I have seen some cases where it has caused some very rough running (without a tune of course - you can tune out many things)
Old Sep 1, 2007 | 05:40 PM
Wayne88's Avatar
Wayne88
I have an '88 Vette with a MAF that has a screen,and that question has been asked a million times
I would say that after twenty years, GM has a reason why they put a screen on the MAF.
However, I don't know what the reason is.
I'll just keep mine on, for now.
Old Sep 1, 2007 | 05:44 PM
Wayne88's Avatar
Wayne88
Probably true, and that would render a ported TB useless.
Old Sep 1, 2007 | 08:13 PM
666vette's Avatar
666vette
Do not remove the MAF screen. The screen is an air straightener which is required to make accurate mass flow measurements. The only way to make accurate measurements without the air straightener is to have 10 times the diameter of the inlet in front of the sensor. I calibrated flow for NASA at Kennedy Space Center for several years and have much experience with flow measurements. There is no reason to remove this screen.
Old Sep 1, 2007 | 08:19 PM
glennhl's Avatar
glennhl
This is an ongoing argument, but I'll throw in my 2 cents. I've always thought the screen was a flow straightener to make the MAF more accurate. Take it out and I've read that some people had issues, but I believe that if you get a tune everything is then fine. I really doubt that you pick up much power, but consider this, the LS6 had a screenless MAF. And I do not believe there is a screen in the LS7 or LS3.
Old Sep 2, 2007 | 02:32 AM
don.donc's Avatar
don.donc
http://forums.corvetteforum.com/show....php?t=1781361
here is one before and after that is logged with hptuners.
Old Sep 3, 2007 | 12:53 AM
BlackMark's Avatar
BlackMark
I removed mine concurrent with the install of my Breathless Vortex Rammer.My car runs like a scalded cat and throttle response is excellent-a definate improvement over stock! Ernie recommends it with his system and has thoroughly tested his system with it removed with no adverse experience.I can at least vouch for it on my car with this ram air system,and I have not had it tuned,only road miles.
Old Sep 3, 2007 | 07:27 PM
carpe dm's Avatar
carpe dm
Originally Posted by 666vette
Do not remove the MAF screen. The screen is an air straightener which is required to make accurate mass flow measurements. There is no reason to remove this screen.
The fact that the car still seems to run well with it removed, is not a good reason to remove it. I have done it in the past, with NO apparent good as the result.
Old Sep 4, 2007 | 07:51 AM
SpinMonster's Avatar
SpinMonster
You post this on every thread for screens and and after a million times I will once again answer the same way I did last time.....GM removed the screen for the Z06 in the C5 for performance....obviously they think it makes it faster.
For those interested, since I did it on numerous cars and had 100% success: Use the 2002-2004 Z06 MAF table and the car runs perfectly. People with real cfm requirements from modding will need to increase airflow and decrease air restrictions upstream of the manifold in order to see 99/100kpa MAP readings. On a stroker it could mean a 100mm throttle body such as lingenfelter's unit that also comes with the tuning MAF table patch peice. No change to the MAF can be done without scaling the MAF table and I dont mean linearly. The Z06 table increases cell to cell more than the screened units do since expected air at higher rpms is increased.
All the stock guys should leave it stock and stop answering for all the modded guys that are looking for a jump in power.
Old Sep 4, 2007 | 07:57 AM
SpinMonster
Wow did the C6-Z06 designers know this too? Where did they put the extra 10 times diameter tubing for the MAF they use in the car with no screen? How does the air straighten out....OMG!! Z06 guys should buy a LS2 air cleaner assembly and get that screen in there fast before NASA finds out and gets all them Z06's grounded for safety. Call the NTSB!!!
The Z06 has the same path for the air cleaner in case NASA doesnt know. It also appears to have the same relative position in the tube.
For the rest of the MAF world: You can buy a housing for the Z06 MAF to be used on any LS2 motor with the appropriate software patch peice from halltech.
To anybody remove screen on maf sensor
Old Sep 4, 2007 | 08:11 AM
SpinMonster
By the way, the wise butt answers are motivated by seeing the exact same statements by the same people time and time again who refuse to take info that comes from first hand wrenchers that prove their info wrong time and time again.
The most powerful and most driveable cars run in speed density without an MAF altogether. Its in the software and prying out a screen with no tuned in changes will not work but if it is tuned in it does. This at some point becomes a required mod along the power curve. Strokers and screens dont always mix. One guy I sold a FAST to reported a drop off in power at 6100rpm and got a 100mm MAF and it pulled to 6700 with increasing power on his 440 stroker. 20+rwhp there and thats a fact. So maybe the stock guys should stop typing what they read from some other stock car owner and leave the mod answers to those that did them successfully so people can learn how to do them correctly for a gain.
The screen straightens nothing and the car is faster without it at a point along the mod curve. The C5 and C6 Z06 should prove the screen isnt needed for straightening air. They dont have one and they outperform the base models with them.
Old Sep 4, 2007 | 08:51 AM
Silver05GTO
So GM putting the screen in to weaken performance on purpose? Julio from Cartek didn't recommend removing the screen and they were about to tune my car, they said it wasn't worth it......and I had a spare MAF in hand ready to rescreen.
Old Sep 4, 2007 | 08:57 PM
owebo's Avatar
owebo
St. Jude Donor '11, '16
The reason for the screen is to push the air flow that goes past the MAF into the turbulent flow regime on the C6 vette. At idle, the flow is boarderline transitional to laminar, which induces a parobolic velocity profile past the MAF instead of a flat line caused by turbulent flow. The parbolic shape allows the MAF to see high velocities and fools it to think there is more air passing it than really is. I did the calculations for my C6 a while ago and posted the Reynolds number for various flows if I remember correctly.
The air flow after the screen is the same as before the screen, what the screen induces is called a minor loss. The pressure of the air is reduced by the frictional loss of the air flowing past the screen. Since the screen is very short in length, the pressure loss is very minor compared to that of the intake pipe and filters.
Mine on my '07 is in.......
