How much torque on wheel locks?
Old Sep 3, 2007 | 04:07 AM
LS WON's Avatar
LS WON
Default How much torque on wheel locks?
On the lugnuts the spec for torque is 100 lbs. What is it on the wheel lock?
Old Sep 3, 2007 | 04:11 AM
Kent1999's Avatar
Kent1999
100ft/lbs, same as the others. Common wisdom just says to make sure the lock is the first lug you loosen, and the last one you torque tight.
