Anyone blown their C6 engine?
Old Sep 3, 2007 | 04:25 PM
Mad*Max's Avatar
Mad*Max
Default Anyone blown their C6 engine?
I've had pretty good luck with GM engines, even after putting high mileage on them never had a problem. Just wondering about the LS2?
Old Sep 3, 2007 | 05:04 PM
pennys58's Avatar
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
We'll...sorta...had a couple rings crack. Just a valid excuse, to the wife, to fully build a 402
John
Old Sep 3, 2007 | 05:20 PM
mfinocc's Avatar
mfinocc
Here's one...
http://video.google.com/videoplay?do...arch&plindex=1
Old Sep 3, 2007 | 06:20 PM
timd38's Avatar
timd38
I know of a few Z06's that have had oil pump failures.
Old Sep 3, 2007 | 07:17 PM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Saw a guy with burned lips at a carshow, maybe thats what he was up to.
Old Sep 3, 2007 | 07:30 PM
Wayne88's Avatar
Wayne88
With the rev limiter, I think its almost impossible.
Of course, maybe I'm wrong.
Old Sep 3, 2007 | 07:49 PM
huckleberrydude's Avatar
huckleberrydude
I could go throw a tank of 87 in and nuke mine right now.
Old Sep 3, 2007 | 07:52 PM
codename Bil Doe's Avatar
codename Bil Doe
No you can't. It's designed to run on 87 or 92. There is a low octane timing table that the computer reverts to when coming across cheap skates and bad gas. Now, if you threw 87 in, towed, and spun it up to 6000 in 105° heat...
Old Sep 3, 2007 | 07:59 PM
huckleberrydude
no! it would nuke. Just the difference in 93 vs. 91 on the dyno with the blower was not good. kaboom
Old Sep 3, 2007 | 08:01 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
The rev limiter only protect you on up shifts. If you shift out of third at redline and accidently hit second instead of fourth you will probably have a blown engine or at least some very serious damage. To answer the OP's question the LS2 is mostly bulletproof unless you or your tuner does something stupid.
Old Sep 3, 2007 | 11:42 PM
jimmybobby's Avatar
jimmybobby
Active Streak: 90 Days
Your location on your avatar -
Old Sep 4, 2007 | 12:30 AM
Ken07AOVert's Avatar
Ken07AOVert
St. Jude Donor '11-'12
Default heeheehee
That was Hucking Filarious!
Old Sep 4, 2007 | 12:33 AM
C6400hp's Avatar
C6400hp
shamefully stolen from " the Dingo"
Old Sep 4, 2007 | 01:36 AM
codename Bil Doe
That's called a ****ty tuner. Give me 5 minutes with 100 octane in your car and I'll give you a tune that'll blow that **** sky high if you'd like. Funny how cars out put over 800rwhp down on 91 octane and are daily drivers.
Old Sep 4, 2007 | 07:01 PM
Mad*Max's Avatar
Mad*Max
The A6 won't let you downshift unless you are within specified RPMs.
Old Sep 4, 2007 | 07:04 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Old Sep 5, 2007 | 12:33 AM
C6400hp's Avatar
C6400hp
Great.
I was speaking of the Mn6, clearly you're not going to accidently shift from redline 3rd gear to 2nd with an automatic.
To Anyone blown their C6 engine?
Old Sep 5, 2007 | 07:19 AM
Mad*Max's Avatar
Mad*Max
Great.
I suspect you haven't tried the paddle-shift???
Old Sep 5, 2007 | 01:36 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I'd say it's pretty tough. Read SOME about it here...
http://forums.corvetteforum.com/show....php?t=1746856
Old Sep 5, 2007 | 03:16 PM
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
I wonder if you did if the c6 would respect you in the morning?
