Hub Removal (same on C5/C6)?
Old Sep 4, 2007 | 04:48 PM
Rob Willis's Avatar
Rob Willis
Default Hub Removal (same on C5/C6)?
Is the procedure the same on both generations?
Will this guide work?
http://www.jakelatham.com/c5/misc/C5...el_Bearing.doc
Old Feb 10, 2008 | 09:08 PM
Rob Willis's Avatar
Rob Willis
..bump..
About time to start the brake duct install.
Old Feb 10, 2008 | 11:14 PM
99FewteRC5's Avatar
99FewteRC5
C5 and C6 susp. is identical.
Old Feb 11, 2008 | 12:23 AM
St.Char's Avatar
St.Char
Originally Posted by Rob Willis
..bump..
The back ones may be a little more stubborn then the fronts. I used a rubber mallot on the back hubs to brake them loose.
Old Mar 7, 2012 | 03:08 PM
Ahmer's Avatar
Ahmer
Theres a z06 removal post about front bearing and talk about removing thd shock bolts as well...
To Hub Removal (same on C5/C6)?
