Knocking noises at slow speed???
Old Sep 7, 2007 | 08:59 PM
beaverwarrior's Avatar
beaverwarrior
Default Knocking noises at slow speed???
I have an 07 coupe with about 3000 miles on it and I started hearing dragging/knocking noises around the front end at slow speeds, does anybody know what's wrong or is this normal???
Old Sep 7, 2007 | 09:05 PM
Miaugi's Avatar
Miaugi
Are you sure it's the front end? Are the noises more noticible while turning? If so, it is most likely your diff.....there is a TSB about noisey clutch plates in the rear end.
Old Sep 8, 2007 | 12:42 PM
carpe dm's Avatar
carpe dm
I bet it is the rear, not the front; the sound is misleading. Check it out and add some LS additive, if it continues.
Old Sep 8, 2007 | 05:38 PM
Duck916's Avatar
Duck916
When my differential clutches started chattering I was SURE it was a noise in the front end.
Probably the posi-clutches.
To Knocking noises at slow speed???
