Trickflow or AFr racing heads?
Old Sep 10, 2007 | 06:10 PM
dstage's Avatar
dstage
Default Trickflow or AFr racing heads?
I did some research and AFR's do not folw as much. They cost about the same. What do you guys think?
Old Sep 10, 2007 | 06:52 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
I heard AFR are the best heads
Old Sep 10, 2007 | 07:27 PM
Silverton's Avatar
Silverton
The ETP 215 heads should put out a bit more peak power than the AFR heads. Check out the dyno chart posted at A & A Corvette Performance under "Heads & Valvetrain" for the ETP heads with the following listed mods: ETP 215 heads, relatively mild 228- 232 Comp cam, LG Pro headers, FAST, ASP UD, and GHL cat back. The dyno chart is from Andy's "personal C6." Cost? $2325.
To Trickflow or AFr racing heads?
