'08 CAGS Skip Shift a no-go
Old Sep 11, 2007 | 03:27 PM
JSVet08's Avatar
JSVet08
Default '08 CAGS Skip Shift a no-go
While changing the oil today I thought I'd install the CAGS Eliminator and no solenoid/plug on either side.
It's not too much of an issue but the few times it has activated in stop'n'go traffic.
I find myself naturally shifting to third everytime instead of fourth.
Just FYI if the info isn't already out there.
Doug
Old Sep 11, 2007 | 03:37 PM
Modshack's Avatar
Modshack
Funny....Mine was there and clearly labled "Skip Shift" on the harness. Passenger side of the trans, up high on the side..
(Remember, the trans is at the rear of the car!)
Old Sep 11, 2007 | 03:40 PM
Michrider's Avatar
Michrider
It's there, same place as always - upper left side. The solenoid on top is the reverse solenoid. The solenoid on the upper left (driver) side is the Skip Shift solenoid. Service manual confirms the same resistance is used, so any CAGs module or 2.2K Ohm Radio Shack resistor will work same as in all the previous years.
Old Sep 11, 2007 | 03:43 PM
JSVet08's Avatar
JSVet08
Usually I am pretty good at DIY stuff, guess I'll have to crawl back under and take another look.
Old Sep 11, 2007 | 04:58 PM
JSVet08's Avatar
JSVet08
Thanks guys!
OK I found it. I was way too far forward and as soon as I moved back, BAM! Clearly marked
Thanks again, I thought I was going to have to sell the CAGS
Doug
To '08 CAGS Skip Shift a no-go
