Koni FSD shocks lower car?
Old Sep 12, 2007 | 06:32 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Default Koni FSD shocks lower car?
Did anyone who installed the Koni FSD shocks wind up with the car sitting lower?
I believe mine is noticeably lower.
GM
Old Sep 12, 2007 | 06:51 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'm pretty sure I read someone who installed them say his car was 1/4 to 1/2 inch shorter. Suggestion was made to heighten the ride at each corner, if they wished.
How's the ride, handling, etc. compared to stock?
Old Sep 12, 2007 | 07:03 PM
Shrike6's Avatar
Shrike6
Somba master
BetterX3
GM
Old Sep 12, 2007 | 07:56 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Originally Posted by gmoller
BetterX3
GM
FSDs and Pfadt poly sway bushings worked very well for me too. The car is definitely lower.
I recommend these mods without reservation for a planted, tire-on-the-pavement improvement....much better handling and ride.
Old Sep 12, 2007 | 09:11 PM
REVAK's Avatar
REVAK
Default koni fsd
GM
I saw a half inch drop after koni fsd install, raised it one quarter inch with the spring height adj. bolts to split the difference.
Old Sep 12, 2007 | 10:00 PM
tigertank's Avatar
tigertank
koni fsd are they for the c6 z06 also? where could i get some? thx
Old Sep 13, 2007 | 11:50 AM
mikesul's Avatar
mikesul
I also noticed a drop after installing FSD's. Hitting the front air dam more often now, so I will raise the car 1/2" all around. Adding lower profile tires at the same time made the problem worse.
Old Sep 13, 2007 | 10:33 PM
KMK454's Avatar
KMK454
So if my car is already lowered does this mean I'll have to get back under it and raise it up some otherwise I'll be too low?
Old Sep 14, 2007 | 10:41 AM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
My car dropped about half an inch with the FSD install. Since I had never touched it before, the ride height is good for me (but the front air dam does hit more than it used to).
Koni FSD's with Z51 sway bars and Michelin PS2 tires have got the car to where I want in terms of ride and handling. Although I might be able to handle a little bigger rear sway bar with the grip available from the PS2 tires.
To Koni FSD shocks lower car?
