LS3 vs LS2 vs L76 fuel rail difference?
Old Sep 15, 2007 | 11:51 PM
blu00rdstr's Avatar
blu00rdstr
Default LS3 vs LS2 vs L76 fuel rail difference?
Any differences between the LS2 and LS3 fuel rails?
Any pics of LS3/L76 fuel rails?
I'm installling LS3 heads on an LS2 forged motor, with an L76 intake. I haven't bought rails yet, don't like anodized aftermarket rails, and my LS1 stock rail is unpretty.
Old Sep 16, 2007 | 12:26 AM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
I will do some research for you tomorrow or monday. I know they are similar, but where the differences are Im not sure
Old Sep 16, 2007 | 10:40 PM
blu00rdstr's Avatar
blu00rdstr
You guys rock!
Old Sep 19, 2007 | 06:23 PM
Former Vendor
Ill have pics tomorrow, the intake is coming off the LS3 car and we can compare everything
Old Sep 19, 2007 | 10:06 PM
Miaugi's Avatar
Miaugi
Will the LS3 intake bolt onto a LS2? If so, any guess as to if it would be better than a FAST 90 on a LS2?
Old Sep 19, 2007 | 10:07 PM
ZPirate's Avatar
ZPirate
2025 C8 of the Year Finalist - Modified
No the LS3 has a different MAF which is built into the air bridge.
Old Sep 19, 2007 | 11:16 PM
stinky's Avatar
stinky
No, LS2 has cathedral intake ports, LS3 has rectangular intake ports...port mismatch.
Old Sep 20, 2007 | 06:53 AM
see5's Avatar
see5
The LS2 and LS3/7 injector length is different. So we may be back to shimming the rail like with LS1 rail on L76. It looks like the L76/LS2/3 all share the same fuel rail so the difference in injector height is made up by the manifold rail mount lug height?
I have some LS3 intakes here but no LS2s (thankfully)
Old Sep 21, 2007 | 02:03 AM
blu00rdstr's Avatar
blu00rdstr
Are you saying the injector length is different between the LS2 and LS3/7, or between the LS1/6 and the LS2/3/7?
I'm curious to see if there are any differences in rail or crossover tube size, or injector angle.
Old Sep 21, 2007 | 10:56 AM
Former Vendor
LS2 injectors are rated 30# at 4 bar. You can swap LS7 injectors into the LS2, which are 40#. The LS2 and LS3/7 injectors swap, but they are a little shorter. Ill get pics today,I promise
The good news is that the LS2, LS3, and L72 fuel rails are the same. With out taking exact measurements, they appear to be the same, with the same 4#'s on them
Old Sep 21, 2007 | 10:57 AM
Former Vendor
The LS1/6 has the older style injector, the LS2 uses something inbetween that of the LS2 and that of the LS3/7.
Old Sep 22, 2007 | 02:01 PM
blu00rdstr's Avatar
blu00rdstr
...The good news is that the LS2, LS3, and L72 fuel rails are the same. With out taking exact measurements, they appear to be the same, with the same 4#'s on them
Awesome, that was the info I was looking for! I'll get an LS2 rail and have some AN bungs welded on the ends.
Old Sep 24, 2007 | 01:26 PM
69lt1bird's Avatar
69lt1bird
Cruising
The LS2 injectors are 15mm taller than the LS3/LS7 injectors.
The top and bottom where the o-rings are at have the same specs for all of the above injectors. You would have to make or buy spacers to get the rail to bolt to the manifold.
To LS3 vs LS2 vs L76 fuel rail difference?
