Possible to add Navigation?
Old Sep 17, 2007 | 08:17 AM
ayeroff's Avatar
ayeroff
Default Possible to add Navigation?
Is it possible to add a factory navigation system to a C6 that didn't come equiped with one from the factory?
Anyone know what all would be needed to do the swap?
Jason
Old Sep 17, 2007 | 10:08 AM
Darrin@Darin U Performance's Avatar
0Darrin@Darin U Performance
Former Vendor
I have seen in some other threads that it is easy to add to a 3LT car but any others is alot of work. If you do a search I am sure you will find a few threads. If I remember correctly you only need an antenna and someone to unlock the option on the car if you have the 3LT.
OK, found this thread, http://forums.corvetteforum.com/show....php?t=1693232, check out post #11. This should help you out.
