autocross questions
Old Sep 21, 2007 | 11:15 AM
glennhl's Avatar
glennhl
Originally Posted by lil red vette
Thanks for all the replys. I'm not new to autocrossing. Just new to autocrossing a corvette. I've autocrossed Porsche 914 fours and sixes for many years. My real love is driving on road courses. I'm a Porsche club driver's ed instructor. The only corvette I've driven at a autocross is a friend's at an autocross. It was really different than my 914. He drove my 914 and was really impressed. Thanks again for all the info.
I autocrossed for years with a 74 914 2.0 liter, then with a 74 911S. A good friend of mine autocrossed with a 74 Corvette. Back in the 80's when I had my 914 we swapped cars at the end of an autocross. First I drove his Corvette and he kept yelling at me to turn in. I kept turning in way too late. Then he drove my 914 and he kept hitting the inside cone on every corner. That was the difference, the 914 would turn in very quickly and that big heavy Vette would push and push.
I think you'll find the new Vette to be a lot of fun. If you get the alignment set up properly it handles great. It will be a little slower to turn in than any of your 914's, but once you get used to it, you can use the power to your advantage.
Have fun!
Old Sep 21, 2007 | 11:20 AM
Buffy's Avatar
Buffy
Originally Posted by foliva
As it is, I've seen a bit of chassis understeer that I can usually overcome with the throttle.
When the runflats go, I'll give the PS2's a try. At that time, I'll also get a performance alignment with the goal of tuning out the push.
I think you'll find that the PS2s are much more responsive to pressure changes, as well as being somewhat stickier to start with. I run them at about 36 front / 33 rear for general fooling around, might go another 10% or so for an auto-X.
And the steering bias can be tuned a bit through camber changes, although so much of the car's attitude is a function of right foot position that I just go for best grip.
I do find that initial understeer has a lot to do with braking technique; a nice smooth roll onto the brakes will plant the front end well and improve turn-in. Of course that's of limited use on an auto-X course where everything happens very fast!
Old Sep 21, 2007 | 05:52 PM
goatts's Avatar
goatts
I heard the same thing from others giving advice to guys new to autocross. I suspect that these guys were talking about non-runflats.
Not the case. He's driven my car. We've looked closely at my tires and they look like they are rolling over when I drop the pressure. I am new to autox (< 1yr).
Old Sep 21, 2007 | 08:29 PM
foliva's Avatar
foliva
After running different types of non runflats on my '93, I was caught a bit off guard with the runflats on my 07/Z51.
Like everyone else, I'd make adjustments on each run & see what effect it would have (time wise & looking at the scrub boundary). I was suprised to see how little effect pressure changes had on both my time & the pattern.
As you state, the '07 requires a smoother hand both on the brakes & throttle.
With the PS2's, when you autocross, do you go another 10% up or down from your street pressures?
